Mister Natural
- Oct 10, 2002
I've known for years that AT&T will drag their feet getting things done when a third party vendor is involved but recently things have become downright hostile. Yesterday I had an outage at a location with business class DSL and the people I had to talk to seemed annoyed and did anything they could to pass the buck to someone else in the chain. Even the tech that arrived on site was useless.
But I have something else that takes the cake. I've never witnessed such hostile behavior until now. Our ISP in the main office is a third party vendor. Back in JULY we initiated a ticket to upgrade our internet from 4 bonded t1's to a 20 Mb connection. This required installing fibre along with the needed hardware.
Since then we've had numerous delays and people intentionally ignoring what it takes to finish getting things done. I'd have to write a book on all the things we've been through but I want to let everyone know just how ignorant AT&T has become.
It took until September for AT&T to get things ready to where our ISP could install their router. When that finally happened it was determined that the patch cable from the MUX to the patch panel was bad. We elected to bypass the patch cable and plugged our cat cable directly into the MUX so we could go ahead and verify the line was up and good to go. We then called AT&T to have them replace the bad cable. Below is a pic of what I left for them.
You can see I clearly tagged the bad cable that needed to be replaced and at the bottom you can see where we bypassed the patch cable and our line is directly into the MUX.
We waited a couple weeks, nothing happened. I checked the dmark last Friday around noon and still nothing. I got a call yesterday and was told an AT&T guy and our ISP tech were going to meet and fix the problem. I went down there at the time given and it turns out someone from AT&T showed up late Friday after I checked. So what did they do?
They removed our line from the mux, snipped it and put a new connector and plugged it back into the patch panel and then removed the tag I put on the bad cable, plugged it back into the mux and left. The ISP tech checked and the connection with the bad cable was still no good.
We cut out the bad cable so AT&T was finally forced to fix the problem. We would have replaced the cable our-self but my boss wanted AT&T to do it and we did not have the right connector for the patch panel anyway.
This behavior is inexcusable and everyone needs to know what AT&T has become.
