Ok, if you look below you will see that it is high time for a new build. My primary interest is gaming and for once I am putting the cash into the best system possible. My number one desire is a solid, STABLE board that will allow for OC'ing if I ever get up the nerve and of course some futureproofing in the form of SLI and dual-core compatibility. That being said I have narrowed it to two favorites with a longshot third, but I have severe concerns.
1A. Asus A8N--Asus has been good to me in the past and this board has been out for a while so it should be fairly debugged. I hear this is THE choice for stability but it is limited in OC'ing, at least with earlier bios'. If I got this I was going to pair it with some low latency corsair 2-2-2-5 so that I can loosen it up later.
1B. DFI Lanparty NF4 SLI--Everything I hear points to this board, but the "plethora" of settings is a little intimidating and I've read lots of horror stories about simply getting it to boot much less run stable 24/7, not to mention this sites review pointing out some stability concerns. My heart says this is the beast to own, but my head says "You Crazy". I would pair this with OCZ DDR 500 VX, but I am concerned about heat issues with pushing 3.2V. If I OC this will I HAVE to add extra air cooling or can I do a moderate clock and survive?
2. MSI NF4 board...I like the features, but I am not quite hot for it.
After the MB, I am trying to decide between Venice and San Diego, but that is a whole other world of hurt. Can't decide if the cache is worth it or not. PSU will probably be a Neopower 480, and GPU probably a BFG 6800 OC. The case is an Antec P-160 with two 120mm fans.
I wouldn't call myself a noob in general, but relative to OC'ing and "current" tech I am as noob as it gets. Kind of afraid of burning down the house as it were. Thoughts, suggestions? Any comments welcome.
