Asus Warranty
Probably, ask ASUS, but if you are clever about putting it back on they will not know until its too late.
Ok i guess I should put it back on. I was thinking about sending it back without out the piece on. I need to buy new plastic spring push screws. Any idea where to buy them?
:eek: I just spent several hours ( I love being obsessive/compulisve) googling every possible combination of " push pin retention spring loaded heatsink heatpipe panel " and several more. Farking things must be manufactured on Mars or something. I can not find anyone selling them in less than 10,000 unit lots.
I did find this that seems to indicate that Asus might charge you a $40 "repair" fee but would take the board in RMA. I am back to suggesting you talk to them or hoping someone else knows where in the world you could buy a handfull of these things.
I dont know what would be best, reattaching it with Nylon #4 hardware or packaging it carefully and including it with the board loose. Anyway I am done. Good luck.
Its post 7 and while not exactly your situation it shows ASUS is flexiable and has some standard way of handling what I am sure they would call end user absuse (removing heatpipe).
http://ubuntuforums.org/showthread.php?t=553533
ASUS has a pretty good warranty program.
I had a dead NB HSF on my A8N-SLI deluxe, I emailed them and they sent me a new one, with pictures of how to rplace it.
I'd try the following first:
go to the ASUS store and see if they have replacement HeatPipes for your board, you may have to spend a few bucks, but the overall warranty will be OK.
If that doesnt work or they dont have them, email Betty_Peng@asus.com she is a great help in things like this.
HAHA this thread reminds me, I had a M2N32 Sli deluxe Vista edition that died 6 months ago and I have not gotten it back yet. Asus confirmed that they got it but I never heard anything back.
Thanks for the feedback. If i can't get the dam pushpins i guess I'll return with out them and include the heat sink. Hopefully there is light at the end of the tunnel.
