Asus T.Probe Phase
provoko
Is anyone familar with asus motherboards and their T.Probe technology? It's supposed to monitor the temperature and voltages of the VRMs... the little cubes around the cpu. So my question is, do I need to install the software in windows for it to work, or does it run automatically without the software? Here's a quote from asus.
T.Probe
Leading Active Cooling Technology
The T.Probe microchip detects and balances power phase loads and temperatures real-time. With optimal power phase functions, components run cooler and extend system lifespan.
Doesn't explain how it works. Do I need the software for this to work? Thanks.
kirbyrj
I would guess that you probably need the software to adjust any settings in windows. Seems a little complicated for bios level adjustments.
