I have installed the two M.2 SSDS disks on the motherboard just set in RAID to the BIOS but it blocks ie it does not fix the problem because there is white led.
It only works if you do not set the RAID if it puts AHCI the M.2 SSDS disks work fine.
The problem is the RAID that does not work with this motherboard failure.
These two M.2 Kingston HyperX Predator SHPM2280P2 / 240G 2x240 disks are compatible with this motherboard.
What do you think? Can you solve this problem?
