Yes, the mobo temp at idle seems high to me, also. Maybe you aren't getting enough air flowing through your case.
My temps are cpu 32C and mobo 28C at idle in the morning...a couple degrees higher in the afternoon. I have six 80mm case fans ( 3 sucking in {2 front, 1 side}, 3 blowing out {2 back, 1 top}) in a server-size case.
well all depends on ambient temperature, OC, case and cooling on the CPU and case. I have a Thermaltake Armor, with extra 2 x 120mm fans added ( one extra in the front and one in the sidepanel.
At stock :1066/1066
MB temp idle is 33°C when room temp is 20°C, though I replaced the thermalpad with AS5dropped 4° C then in comparison...
Also for the CPU temp don't use Asus probe to read it out, use Coretemp instead or the latest Everest home which reads out he coretemps which are more reliable then the sensors on the mobo.
I put a sensor ( opt2) on the heatsink cooling the the NB ,even at stock it gives me 50°C which is really hot when being non overclocked
