Chacranajxy
- Nov 11, 2005
So has anyone with the monitor done that precise method of testing lag that someone mentioned earlier? That's really my only concern with this thing... if that's not a problem, I'm sold.
SNIP
Here are my updated thoughts as of now
Now I cant wait to get some really indepth reviews from sites. I want to see if this LCD is worth the 100 more than the ZR24W.
Well from the sound of it , it isn't a big improvement at all over the U2410. Too bad , I'm still curious about the more professional calibration values it can hit but it doesn't really sound all that much better.
Guess I'll continue to wait.
I don't see how it can be much better than the U2410 when it effectively is a U2410, even down to the electronic behaviour.
And I found another stuck pixel.... this one also near the center but it appears to be nearly dead as it's not noticeable from normal viewing distance. Amazon shipped another which will be here on Tuesday.
I did an online calibration this morning and I'm more pleased with the colors. The black levels, however, are not as good as the MVA panel sitting next to it.
so if you want to impress the ladies, the Asus is the way to go!
Response time picture from PixerPixAn would be nice too if you have a camera that you can set the Shutter Speed to 1/100 second.
I have a question to owners of PA246Q. What about brightness of this model ? What is minimal setting ?
I'm asking because Dell 2410 is very bright and going down with it decreases contrast and colors quality. HP ZR24W in the other hand does not allow to set luminance below 132 (however keeps contrast stable).
I used to work\play at night, high brightness make my eyes suffer
Thanks in advance for replies.
I recieved mine today and I also have two dead green pixels.Not in the centre but Asus qualitycontrol seems to suck!!!
Apart from that the monitor seems allright although the blacks doesnt impress me. Its going back. Will have to wait for something else. Samsung SA850 maybe if it is decently priced.
Performance wise, ASUS PA246Q appears to be very similar to the DELL U2410.
I suspected this is essentially a Dell U2410 in a different case. Asus likely builds the U2411 for Dell.
As far as the AG differences, I am betting that it is largely placebo. This is almost certainly the same panel from LG.
At least electronic and panel are identical. U2410 and PA246Q show the same nonlinear behaviour in the picture mode with access to RGB gain controls.Highly doubtful that they build for Dell. Not sure though. But doesnt seem likely.
Qisda designs/assembles the U2311 for Dell. Since the rest of the range is so similar in design and functionality, it would be downright odd if Qisda wasn't the manufacturer of those too.
Not sure what Asus really produces these days by themselves when it comes to monitors.
According to tftcentral's U2410 review, it has an average input lag of 33.8ms (max 40ms) in standard mode, while in game mode input lag drops down to 14.4ms average (max 20ms). I don't know if ASUS has separate game mode like DELL, but in standard mode their input lag should be very similar, according to the above mentioned review ASUS' input lag falls in range of 30-40ms, with max value of 50ms.
After reading all posts here that mention stuck/defective pixels, I'm having second thoughts about this monitor. In addition to this Amazon also removed this monitor from their store (it can only be bought from third-party sellers), which I'm guessing is due to higher return rate because of pixel defects. And after really bad experience while trying to buy DELL U2410 (I went through three units with various defects, before giving up), I was really hoping that this monitor would be my next purchase. Though luck.
Looks to me like their QC is poor just like dell's was.
