Give bios 0407 a try?
ftp://ftp.asus.com.tw/pub/ASUS/mb/s...olution/BIOS/P6T6-WS-ASUS-REVOLUTION-0407.zip
I have Tri SLI working with my rig posted above. I did however add 1 card at a time and get that card working first. Also I added first slot then 5th slot, then 3rd slot. i used the tri sli bridge for 2. I also am currently using Vista x64 with all updates and NVidia driver 182.08. Hope this helps. Also I booted to the Bios with each new card and saved the changes. I am using ASUS for plug and play not the OS.Gents,
My P6T6 WS Revolution came with a 0311 Bios.
I've tried and tried and tried for 3 days to get Tri SLI to work. Tried 64 bit and 32 bit Vista. Tried four different video drivers.
I even bought a fourth GTX 285 card just to make sure it isn't one of the cards that is busted, and I verified each video card in a separate machine.
Windows Device Manager sees all the video cards. GPU-Z reports all the video cards.
All I can get is Two Way SLI. Enabling Tri SLI is not an option, and the third video card gets disable. I have swaped the video cards around in limitless combinations.
I am at wits end and I have no idea what else to do.
Nvidia says it isn't them. Asus is amazingly quiet, even after I invoke the Kyle Bennett name. I have triple checked the Bios version a million times to make sure that I am not blind and dumb. It is bios 0311 on board.
I don't know what to do. Help please! Please! Pretty please? !? !!
Anyway, I'm supposed to be folding, and not gaming (going to use five video cards in single slot water cooling), but it would be nice for once for the darn hardware to work properly!
Thanks Gentlemen. I don't happen to have three spare flex bridges and I have ordered a Tri connector from EVGA.
I followed the proceedure recommended by Churley818 above, and it didn't work. I am convinced its the Tri SLI connector.
Thanks very much.
Well gentlemen,
As an update, I re-installed Windows 3 times this past weekend, using both 64 bit and 32 bit Vista Ultimate. I used the Nvidia 182.08 drivers.
The motherboard bios is now 0407, but I hear there's a 0501 bios now. I spent ***EIGHT*** hours doing nothing but toyinga nd trying to get Tri SLI to work. I installed nothing else.
Well, all four video cards work beautifully independently (three EVGA and one BFG). What they won't do is work in a Tri SLI setup.
I remained convinced its the Tri SLI connector, and I have an EVGA version coming in the mail. ***Asus wants nothing to do with me, and I really think they want me to just go away and disappear***
If the EVGA Tri SLI connector doesn't work, then its the motherboard, and unfortunately, I'm going to relegate it to an office PC for my wife.
I've spent enough time on this, and going the EVGA Classified route is not my first choice, but if I have no other options, its what I would have to do.
And Asus.. you are big and powerful and don't need me as a customer.. I'm sure of that... but I have bought easily 50 Asus mobos over the course of my hobby life. With the way you are ignoring me and with the time I have spent/wasted, this will be my last....
Really enjoying this board so far. Hate the ps/2 port blemishing its perfection.
You crack me up! Believe it or not I use it because I have old IBM keyboards (PS/2 ports) with the best clicking I love to use. The board is the bomb!
I had one last thought for you, you probably know way more than me on PCs it sounds but could it be your power supply is not powerful enough to drive all your parts and the third card, are the lights on the third card green?
Now, I'm starting to enjoy this motherboard!
As I suspected correctly, the Tri SLI connector from Asus was busted. I ordered a Tri SLI connector from EVGA and it took forever to arrive, and then it took two delivery attempts because EVGA refuses to sell without a signature for the UPS parcel, even though I have a no-signature-required contract with UPS. Of course, nobody's home during the business day.. doh!
The wait was worth it, because Tri SLI works beautifully now. In fact, I went overboard with the excitement and have since installed a fourth 285 card with single slot water block for Physx. Now, I want a fifth 285 card
What are your 3DMark vantage scores?
My best on air cooled only is 36059 with 12 GB memory (this much memory keeps me from increasing the BClk to get real serious overclocks)
Here is my Vantage link: http://service.futuremark.com/compare?3dmv=921320
How come there is no mention of the P6T6 Workstation board. (the one with PCI-X slots)?
I'm using the Revolution - will never use SLI let alone Tri SLI and am concerned about the heat output of the NF200! That puppy is the hottest thing in the case and the IR thermometer confirms Kyle's findings as well.
Furthermore, I need 1394a which this board does not have and had to purchase a PCI-E 1X card (1394a/b) based on the LSI chipset which the WS board has onboard along with a PCI slot.
I'm wondering at this point if it would be worth it to go the WS route? Stability and speed is perfectly fine.
12GB Corsair Dominator at 1600-8-8-8-24, 1.6V etc. http://www.youtube.com/watch?v=zCTiWgntIMM&
yea but not with HT on.
I have to seriously wonder the value of HT. The original HT slowed the box down in our tests under load it didn't help because it shared resources (I believe thats why they took it off the market it was defective). I haven't had time to inspect the new HT.
This is a limitation of the memory controller on the CPU and not the memory itself, here is an article which may help explain this limitation (although it does not mention X58 specifically, the same limitation is true for all motherboards):
This isn't quite true. Boards supporting registered or fully buffered DIMMs do not have these issues. I get your point but it is somewhat inaccurate to say "all boards have the same limitation."
I wouldn't worry about it. All nForce MCPs run hot. They can handle it. As for the PCI-X version of the board, I'd avoid it unless you need PCI-X slots. People upgrading existing systems that do not have the money or desire to replace the PCI-X cards may find value in it but for new builds I'd say just go all PCI-Express.
I could actually use the PCI-X slots with regular PCI peripherals (audio interface).
How would this compare to the EVGA classified?
Rubycon,
Apples and oranges. The WS Pro mobo is fabulous, for sure. And so is the Classified. However, its a different ballgame. The Classified is meant for gaming machines, and the WS Pro is great as a workstation.
As for me, I chose the Revolution because I have ambitions to run five video cards (now knowing that six video cards is problematic) to maximize my folding contribution. I cannot do that with PCI-X slots, and therefore I chose the PCI-E mobo.
Oh BTW it does SAS too which decimates velociraptors SATA.
Yes but I don't use the onboard SAS - I have an Areca 1680ix with 10 15K Fujitsu MBA's.
I DO like having a plain vanilla SAS controller just in case I get a drive that acts weird and I want to run a program on it to check it out. Most diagnostic programs don't work right "proxied" through a smart host.
My only gripe with this board is the choice of NIC. Realtek? Should be at least Marvell/Broadcom or Intel IMO. Probably a nitpick but no complaints of speed as I hit mid to upper 90% on transfers on our gigabit LAN using Catalyst switches.
Well Churley818,
I don't know much about 3D Mark Vantage. My score stinks.. 35+K.
http://service.futuremark.com/resultAnalyzer.action?resultId=948896&resultType=19
And that cpu is not overclocking properly because Turbo is not recognized within Vantage. I'm losing a full 200 Mhz. Tomorrow, I'll pump it up to 4.15 Ghz (sort of my max overclock at the max voltage I'm willing to use long term.. 1.4 volts). Anyway, my cpu overclocked is not doing so well in Vantage. I have to figure what's going on. 12 GB of memory seems to be a big advantage. Looks like 32 bit OS takes a hit as well. It looks like non-NF200 mobos like the Rampage II and EVGA are netting an extra 1K points.
Plus my video cards need to go on water before I'm willing to really push them. So far,the overclock has been conservative at 703/1601/1328.. and its not performing to expectations... yet.
Will get back to you on how I do on Vista 64 and 12 GB of ram.
