Asus P5W Wifi
loxety
I've got a Asus P5W system that I just installed Vista Home Premium 64bit on to. I can seem to find the access point software for it, can anyone point me n the right direction? I have looked on asus' website and found a file (ASUS_WiFi_AP_RTL8187_V6126212122006_Vista) that looks like its the solo ap install but it just ends up reinstalling the driver for the wireless card. help!
What was on the CD? IIRC, if you use the Asus wireless program instead of the Wireless Zero Config, there is an Access point option in there.
Actually, my wireless never worked right with the P5W. I was disappointed personally.
In windows xp the wireless worked good.. the secret to getting it working well in xp was to set it to work in 802.11b mode not b/g. When set to b/g the wireless connection would be unstable to say the least. With xp installed I had the system setup as an access point for almost a year until this recent windows vista install. I was able to connect to the system with my laptop and gain internet access through it. I am trying to do the same thing in Windows Vista.
In windows xp there was a separate piece of software that you installed after installing the driver that would control the wireless card and I would use this software to set the card to be used like a wireless access point. It worked exactly like the D-Link and Linksys wireless routers I've used in the past (nat, dhcp included).
