Asus P5W DH MP3-IN Function - Anyone Using It?
abcdelight
Hi, I was wondering if anyone successfully uses the MP3-IN connector on the P5W DH and how you did it? That's the function that allows an MP3 player to use the computers speakers even when its off.
I have the input attached to the reddish connector to left of mobo just as the photos show but I get no sound when computer is on or off. I tried different settings with the Realtec interface and nothing changes. For sound I use the Realtec driver off the disc I got last Sept since the current site driver always tells me its not for my OS even though I use the one labelled for XP (I am on XP MCE). I can get the MP3 player to work via other inputs but not the green MP3-IN jack.
I have Googled to no avail and I have been to the ASUS site but a search there only shows a couple forum posts nobody answered. I didn't see much here either
Haven't tried it since I use my X-Fi.
First thing I'd do though is check out the "Digital Home" features in the bios and see what they do. They are disabled by default.
Thank you. I looked at the manual and inside the Bios and nothing really jumps out at me. I see some choices between HD and legacy97 for front inputs but not much after that.
It's one of the last pages in the bios. Can't remember where exactly, but I just saw it the other day.
Thanks - looked again in Bios (1701) and still don't see anything. I guess not many people use this feature since I don't see much about it anywhere.
Ah - I found the Digital Home bios option. It was under "Advanced" and then "Jumper Free Configuration". I enabled the digital home function but I still cant get anything from speakers : (
I have used it once but the sound quality is horrible and volume very low (ipod turned up all the way). I haven't used it since
Thanks for info. I listen to pod-casts of talking mostly and thought it would be decent to be able to use the MP3-In. I got the Asus instead of Intel because of things like this and the remote and the wifi - and they all have issues! Haha on me then. Next time I know better hopefully. Frilly stuff on electronics usually often out to be useless.
