I'm having a bit of fun playing with my Asus P5Q motherboard. It comes bundled with some s/w that should allow my 2 x 500Gb to operate as some form of RAID pair. I hate setting up RAID and Asus appear to have taken all the trouble out of this by simply allowing you to hook up 2 disks to dedicated SATA ports and installing and running a wee bit of s/w.... BUT, I can't get it to work properly. To install the s/w one needs an OS on which to install it (in this case Win XP Pro x64) so the first disk has the OS installed on it. The BIOS does not seem to see the second disk at all (when using the orange & yellow SATA ports as recommended in the manufacturers operating instructions). When I proceed to run the "double speed" (which I presume is an auto RAID setup) it tells me it is going to wipe all disks. Maybe this is correct but wouldn't it mean I have to setup my OS again? I am prepared to run the OS installation again but only if I know it is going to work. Have any of you HARD FORUM geeks had a similar experience? How did you get on?
Thanks
Thanks
