Asus P5N7A-VM with hardware RAID card?
mr. texas
I have an Asus P5N7A-VM motherboard and would like to do a hardware RAID 5 array. What card would be compatable and what would you recommend?
Thank you.
1) What's your max budget for this hardware RAID card?
2) How many drives do you plan on using?
3) What hard drives are you planning to use?
I would like to spend around $350 on the card.
I want to use 4 drives, so a 4-port card would be fine.
I want to use WD 1tb green drives, I already have one and would like to buy 3 more.
Should the card be PCI-express?
also, i would be open to a RAID 6 array if the card would support it, pros cons?
Ok, you're not going to be able to use the WD Green 1TB drives in a RAID 5 array anymore since WD disabled TLER support/switch on all of their non-RAID/server class drives. SO you're gonna have to go with 4 new drives.
Yes the card should definitely be PCI-E.
Figure out what drives you're gonna use and then we can start recommending controllers. Seems like virtually every hardware controller for sale now on Newegg has a problem with a certain hard drive brand or another.
Like I said, any non-RAID/server specific WD drives made after October 2009 will no longer have TLER options. That includes the WD 1TB Black drives.
As for that RAID controller, read up through these threads on the forums and try to get a good idea of what you're getting:
http://www.hardforum.com/search.php?searchid=13854019
Now if you want to stick with that 3Ware controller, I recommend getting this Samsung drive since it's actually on the hard drive compatibility list for that controller:
$90 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
