asus p5n32-sli
VladDracule
hello all. i recently built a computer using an Asus p5n32-sli board. many of the reviews on newegg complain about it not supporting anything more than 2gb of ram and this of course is a concern. i was wondering if anyone here has any experiance with this board and this issue that many people mention.
Which p5n32-sli? There are lots of them.
Either way, Asus website says they all support up to 8GB of memory (except for the older NF4 edition that's non C2D ready which says it supports up to 16GB of memory). I'd trust the Asus website over some random newegg review.
I have that board and I am having troble getting 4gb to work. I have contacted Asus and PQI and so far the point the finger at each other. If you have to have 4gb I wouldn't get this board, other than that I really like the board but 4gb is a major bummer.
is there possibly a bios update that you can correct this with? have you flashed with your latest bios? im thinking a few months down the line ill invest in another board and just keep this one to build another comp off of later on
703 was just came out and it says is fixes some memory issues, but it faied to reslove mine.
As for using 2x2GB it may very well work I've not heard of anyone tring it yet. The worst part of the whole deal was Asus tech telling me that if the bios mem check passed then the problem was with windows. I now have no respec for there tech support.
It is super easy with this board. you can use either a flash drive or a floppy drive.
You hit alt + F2 (I think) to get to the utility or just go into the bios and select tools and then
select ez flash utility. You can also do it through windows but IMO doing it through bios is much safer. Just go to Asus website and you can download the Bios file you just need. unzip it and copy it to your drive it will be a ".bin" file.
The book explains it very well
Good luck
