ASUS P5N32-E SLI and setting Vcore
3NF
I don't know what the deal is, but now it seems that if I try to set the voltage manually for vcore in the bios, the value never really changes. I'm version 0405.
Example:
The AI Mode is set to Auto. In this case, if I set Vcore manually, reboot and then go to the hardware monitor screen it shows a value about .02 below what I set it at. This happens for any value I enter in the BIOS - seems reasonable.
However, if I set the AI Mode to Manual, meaning I want to set the FSB and memory speed manually, changing the Vcore value in the bios never seems to have an affect. No matter what number I enter, I always see 1.37 in the hardware monitor section.
Any ideas??
Sounds like a minor bug waiting on a new update from Asus, Btw Hi 3nf oldman(co30). I changed my mind to this board and have watched your posts waiting to see how you make out, the Striker is just to much money, but I do want the 680i setup.
I just ordered the board, how do you like it so far? I had the choice of this and the striker but I opted for this, I think it will fit the bill.
Hey Oldman! I haven't reinstalled Unreal yet - but I will soon and jump on your server :)
ellover009 - I like this board very much. I'm not running into any sort of "hardware" issues like others have been. The BIOS just seems to be a bit "borked" up at the moment. I may roll back to 0302 and see if that changes the voltage "stick" problem that I have. I'm hoping (and assuming) this will be addressed in a future BIOS update.
From the research I did the asus motherboards don't have many issues as other brands, it's mostly has to do with o/c, from what I understand is the P5N32-E SLI is suffering of less of these issues.
Well, here is some info in case it might help others.
Using Bios 0405, I set Vcore to 1.40 in the BIOS (actually, it doesn't matter). The Hardware Monitor reports 1.38V and a temp of 40C. CPU VTT is set to auto and the hardware monitor says it's 1.36. With this setup I can overclock my E6600 at 3.375 GHz without any problems. Overclocking at 3.6GHz isn't stable (as I can't get the voltage any higher!)
I rolled back to 0302 and to get Vcore to show up as 1.38, I have to set it in the BIOS as 1.5! Now, the idle temp is 50C! To get CPU VTT to say 1.36V, I had to set it to 1.3! Leaving it on the 'Auto' setting would only register it at 1.26V. At this point, the voltages between this setup and the one above appear the same - the only thing that stands out as different is the temp. Well, guess what - with this configuration I can easily overclock to 3.6GHz, stress the heck out of the system, run 3dMark06, etc., - stable. Hmmm.
What's the deal? I think that whatever number you see in the BIOS is wrong! Don't believe anything! I could spend the rest of the year playing around with this and blowing my mind to pieces! I'm going to stop overclocking for awhile, and just enjoy my system and download PORN! :D
I have my e6700 at 3.25Ghz and I havent touched the voltages. I unlinked the memory,kept the frequency at 800Hz and have only adjusted the FSB. My board is rock solid stable.
Believe it on not I'm using the release BIOS, its 0202 and its not had one single issue.
I'm with you guys, I really like this board. :D
It's nice to read good things about a board, just a shame that we have to find their bugs and fiddle and wait for them to update something that they should have tested. Lets face it they know what were going to do out of the box so it would be nice of them to try it before we get it. I feel this will be my board now. :)
Asus always has random Vcore droop issues. I have my P5W DH set at 1.385 and it gives me 1.34V. I set it at 1.40V and I get 1.35V.
I agree. This isn't the type of board you buy and then never go into the BIOS :)
I have a ASUS P5N32-E SLI and i am experiencing very similar problems as the evga users do_Of course there might be other issues but i cannot install xp ,sooner or later the pc hangs when a hardrive is connected and at the asus forum several others have sata/raid issues that mirror mine.Nvidia says ours boards are not affcted yet its happening .i upgraded to asus latest bios wich does not adress this problem specifically so it didnt help.Just wondering what you guys think,can nvidia be mistaken ,can this be the same thing or is it just a coincidense ?
Tried several disks but if i get as far as installing xp it wont complete,hangs in the first minute or so and bluescreens with disk errors or cant create product folders,other times it just locks solid.ASUS support wasn't of much help either,they said reset default values in bios then use optimal settings,then use the latest chipset driver(wich i found very odd since i explained at length that the os wouldnt install,i found it somewhat problematic installing chipsetdrivers then)Any insight into this would be greatly appricciated,if there can be a connection between this and the evga problems or if its something else that can cause it,According to corsair my ram is compatiblle with this board,every other component besides the cpu are tried and tested in a older intel dual core 3.2 ghz machine.
Speccs:
Core 2 duo 6600
Asus P5N32-E SLI
BFG 8800gtx
Corsair vs2gbkit533d2
Seagate 320 gb sata 2
Tagan easycon xl 600w
I take it your setting it up default just to get it going? And try one memory stick just to get it going and at what voltage did you set your memory to, some one else can back me up here , but I thought I read some place about doing this. Wish I could help more, but I have only read about issues so far I held of on buying a board till the new year.
Great news of your success with this mobo. What kind of memory are you using?
I use Corsair XMS6400C-4(800Mhz)
By the way, my vcore is 1.12V and my board is rock solid.
I havent had to fiddle with my memory voltage either. Even though this memory is rated at 2.1 it runs fine at default, which I believe is 1.87 or there abouts.
I essentially have a stock board,Bios 0202; stock voltages; and have run the FSB up to gain this really meager OC..............but its stable and fine with me. My goal is to fiddle with this board and get the CPU up to 3.5 if I can. It will take some voltage adjustments I'm sure. At the moment I have the CPU at 3.45Ghz running Orthos for the night and havent seen an error yet.
