Asus P5K memory question
hossdaddy
I am running the ocz pc6400 platinum XTC rev 1, 2gig kit. OCZ says that it should have 2.1 v
but when i set it to 2.1 in bios it wont post? It is in there at 1.8 V now. I have read that some people are putting in only one stick and setting the voltage to 2.1 then turn off and add 2nd stick. Can anyone help me out here? Also this ram isnt on the QVL list but OCZ usually runs well on Asus boards. :confused:
Well the big question is, at 1.8V will it run at the advertised timings and the machine is stable playing games or whatever. If so, you are golden. Most voltage increases are there because the ram chips require the extra boost to meet the high performance settings. Really good ram would run fast without the voltage boost.
Set the timings per the manuf specs and try it, then 1.9V then 2.0 v if you can get the ram to run at spec at a lower voltage, its easier on the ram and a better situation.
If you intend to go for a high overclock it might be a problem but it is somethign you would need to test.
All that said something sounds funny, try posting in the memory section but include more details as to your memory settings in the bios. An OCZ rep hangs out there and may know what is going on.
There are big problems with OCZ RAM with this mobo, check out the official Asus forums.
My Geil RAM wouldn't work at 1.8V, BSOD on OS load. 2.1V sorted it, currently OC'ed it to 880MHz
ok here's what I did
turned off machine
took out 1 stick of ram
booted up machine
changed the timing to 5-5-5-15
changed the voltage to 2.1v
saved and exited bios
machine booted up properly
checked e-mail
shut down machine
installed the 2nd stick
rebooted machine
done
ram is @ 2.1 v
The OCZ specs say it is designed to run @ 4-5-4-15 @ 2.1v so I am going to play wround with that.
Any suggestions?
ok I am happy to say that after much help from Ryder and teh ocz technical staff on different forums I now have my OCZ ram running very nice on my P5K mobo at the specified speeds!
AFter reading the asus forums and varies boards I have come to a conclusion that many people are having trouble with ram on this board but dont bother to try and fix it or seek help. People you must investigate a little it is worth it believe me!
Thnx again Ryder!
The P5K does a very bad job of setting the RAM timings automatically. Manual configuration is essential
As a solution, you could stick in a small stick of DDR 2 in that can run at 1.8v to change the voltage to 2.1v.
Spicey, whenever I try to adjust timings I get boot problems. Automatic works fine for me.
Yeah but you are probably not running the RAM at optimal performance. What is CPU-z reporting the memory speeds as? (notably Cas Latency) On mine setting Auto set it to 5-5-5-18 1.8v when it should have been 4-4-4-12 2.1v, it makes a difference to performance, SiSoft Sandra shows it as few % quicker.
Update:
well I am sad to say that this morning I tried to boot my pc, it would not post and would not give an error message. SO I will recap all the issues in 2 weeks with the Asus P5K
- would not save the boot config
- would not save ram timings
- onboard audio crapped out after 1.5 weeks
- decided to freeze with no error msg and would not boot with an ultimate boot cd in drive
all that = return to store and brought home a Gigabyte GA-P35-DS3L, am I am happy to report that it is up and running with having to re-install the os and with minor adjustments.
Post Tools
You might have just got a faulty board or damaged it during install. I know a few people with a P5K and they all recommend it, I also have one myself.
I too have bought a ASUS P5K but with a "R". It give me some boot error message. Is that your problem too?
well as you can see I do not have the problem any more. The P5K was just giving me too many problems. So, i returned it and got teh Gigabyte in my sig and must say its a solid board.
I was actually going to buy the Gigabyte one instead but they were out of stock. The PK5 VM was my second choice. It did get solid reviews like the gigabyte mATX.
5 5 5 15 at 1.8v 2T
I'm running mine on Auto also now. It seems that my Geil RAM is really fussy with this motherboard. Sometimes it works great at 4-4-4-12 other times performance seems to degrade. Auto seems to correct all the problems, so I guess it does a decent job afterall. Overall it's and excellent board for the money.
I've overclocked the FSB to 280MHz and so the RAM is running at 840MHz. This scores 5.9 in Vista for Memory. Before OC it was 5.6. What scores are you guys getting with Vista benchmarking with this motherboard?
