yes this graphic card really rocks!!!
http://i209.photobucket.com/albums/bb261/pvhk/700.jpg
the fan speed is @29% by default!There's alot of discussion about the loudness of the 8800GT under load, especially when playing the Crysis demo. Whats your opinion on the noise for the 8800GT under load, pvhk? Supposedly when it gets over 45% speed it gets pretty loud. I read people have been fixing the speed at just under 45% for heavy 3D game play.
Acording to the board's manual, there are three PCI-E slots (1@16x, 2@1x), the PEG slot being full-speed. I don't think you'll have any problems with that one.Does anybody have any idea how the PCIe lanes are distributed? I mean is the main PCIe x16 slot full speed even if integrated graphics is used (with one or two displays, even) and does the gigabit ethernet chip use PCIe or PCI (not good for speed). The manual didn't mention this, unlike the excellent Gigabyte manuals I skimmed through while checking out the GA-G33M variants (-S2H was a letdown, it has integrated DVI but the main PCIe is only x4 and ethernet was on PCI).
Damn, this sucks. I've never used systems with integrated graphics so I wasn't up to date on this behaviour; that it still works like this. It bloody well should be supported. I'm thinking of driving three or more monitors with a microATX system, with a large GPU cooler on the primary discrete card - there might not be room or free slots for another discrete graphics card.The Intel IGP doesn't usually work with external GPUs. As soon as a PCI-E GPU is put in the PEG slot, the IGP desables itself. On the GA-G33M-DS2R, the manual clearly states that using ANY GPU on ANY PCI-E slot will result on the IGP being disabled... Not so on the X1250 IGP, which supports "Surround View" with ATI cards.
If somehow you found a way to have both the PCI-E and the IGP working on Intel chipsets, that may well be the cause of the PEG slot speed reduction, since it's not a supported feature, AFAIK.
Indeed, I'm just planning for the future in case I build a fileserver over Gigabit LAN someday. That would or could be faster than a local disc if the CPUs on both ends are up to it.On 10/100 LAN environments, there is no performance loss between PCI and PCI-E, the bandwidth is just not a factor.
Using a PCI graphics card is, I guess, my only hope and even that isn't fool-proof - first I'd have to find a PCI graphics card from NVIDIA, have a free slot for it and then hope the OS doesn't play dumb when I try to use separate, different drivers for it and the main card.Also, do keep in mind that the PCI bus is becoming increasingly "free". Nowadays, on an Intel chipset, you only have the legacy IO chip on that bus, which is not that much... Everything else is either PCI-E or has dedicated buses (like HD Audio).
For three monitors, I think only the X1250/690G ATI, and perhaps the 6000 and 7000 series NVIDIA chipsets can handle IGP and GPU (from the same manufacturer, mind you) at the same time. NVIDIA is also preparing something called "Hybrid SLI" that can also help you there. As for Intel, the multi-GPU approach is not available because... well, Intel doesn't manufacture dedicated GPUs... heheheDamn, this sucks. I've never used systems with integrated graphics so I wasn't up to date on this behaviour; that it still works like this. It bloody well should be supported. I'm thinking of driving three or more monitors with a microATX system, with a large GPU cooler on the primary discrete card - there might not be room or free slots for another discrete graphics card.
Unless HDD technology changes a lot in the next few years, or you use big RAID arrays for sequential reads, you won't be able to cap the Gigabit badwidth that easily. Sustained 75MBps (600Mbps) is not that easy to achieve...Indeed, I'm just planning for the future in case I build a fileserver over Gigabit LAN someday. That would or could be faster than a local disc if the CPUs on both ends are up to it.
Well, good luck with that one. Do keep in mind that it seems Vista only allows one VGA driver, and the FX5200 (the only ones I know available on PCI format that work with Vista) uses a different driver than the newer 6, 7 and 8 series...Using a PCI graphics card is, I guess, my only hope and even that isn't fool-proof - first I'd have to find a PCI graphics card from NVIDIA, have a free slot for it and then hope the OS doesn't play dumb when I try to use separate, different drivers for it and the main card.
I find it hard to believe this is so complicated. On the other hand, multi-monitor support is probably usually provided for professionals and business environments by Quadro or other such cards, and gaming cards have never been considered part of the equation... The setup I need is probably two monitors on the main card (some NVIDIA card possibly, like I now have) and a TV on some second card, with hopefully a digital connection to eliminate analog worries. Finding an old, supported card that can do that is the problem there. It might also have to be a PCIe x1/x4 card for these new mATX boards.For three monitors, I think only the X1250/690G ATI, and perhaps the 6000 and 7000 series NVIDIA chipsets can handle IGP and GPU (from the same manufacturer, mind you) at the same time. NVIDIA is also preparing something called "Hybrid SLI" that can also help you there.
Which wouldn't be the goal either, but just something faster than a 100Mbit LAN with some bandwidth in use already.Sustained 75MBps (600Mbps) is not that easy to achieve...
I'm steering well clear of Vista anyway. The only problem may be with having to install drivers from different releases of ForceWare - I have no idea if the newest one's control panel can still talk to older drivers from previous versions. They do drop older cards from the package from time to time, don't they?Well, good luck with that one. Do keep in mind that it seems Vista only allows one VGA driver, and the FX5200 (the only ones I know available on PCI format that work with Vista) uses a different driver than the newer 6, 7 and 8 series...
Good to hear. Is there anything special involved with installing cards of different models, and even makes? Do they all still support hardware acceleration (something I was told might not work, but I have no time or hardware at hand to test these things at the moment). Pretty much the only requirement for such a PCI card I need is a DVI connector in the back and high resolution support, at 1920x1080 (or 1200). (I've tried S3 cards with older machines by the way and I know they're a pain in the ass to use.)In XP is easier. I've had multiple VGA cards working hand-in-hand in XP, and with different GPUs. Do steer clear of S3 cards, though, since the only way to make them work in XP is with them being the primary display adapter, which is usually not a very good idea...
Are they even out (in the States) yet?Anyone got theirs yet?![]()
I haven't seen it yet. I'm also keeping en eye on it, I don't know if I should replace my abit F-I90HD with this one. I never had a problem with my board unlike many other but maybe I should not push my luck further.
Also, I email twice abit if this board would run the new 45nm Penryn and I never got an answer.
Now I read there is also the ASUS P5N-EM HDMI with nForce 630i that is coming but no other spec I can find and no official annoucement I can find either. Is the nForce 630i a better solution than Intel G35 / ICH9R? I have no idea.
If you're happy with the F-I90HD, I don't think why you should change it. But, if you DO want to change it, I won't mind taking it for freeThe nforce 630i P5N-EM HDMI does not match the P5E-VM HDMI in term of performance wise!
That's weird!!
Allsop, Does it have the same or better max fsb compared to the p5k-vm?
What is the module upon the pcie16x slot?
How did you perform the the vdroop mod, like the p5k-vm?
could you post a screen of the resistor to pencil?
Thxs allsop!
btw: did you test all the 3 bios available including the 1st beta?
The idea to perform the pencil mod on both resistors... it could improve something (increase the voltage a bit more)???
Thx
I'll try this: http://sg.vr-zone.com/?i=3904 with your Vmod ASAP
Thx allsop
Thxs again for your vdroop mod!The board came with bios 0202 and now I'm on the latest 0301...
In the picture below you see which resistor to pencil, it's the one marked red.
Alternative you could pencil the resistor to the left of it.....
Your biggest problem there will be finding a PCI card which is Vista-compatible. The only ones I know of are FX5200-based NVIDIA cards, which are VERY rare (I think they are made by Club3D, but I'm not sure).Curious to know, if I use the intergrated HDMI/VGA and a PCI (non E) graphics card, will this work ok with Vista Aero? Or would it still be a problem since Vista only likes one driver?
