I can't get the IDE devices set up right on this mobo - ASUS P5DG2 "deluxe".
I have two IDE devices: A DVD and Samsung HDD.
I don't know if this the way it should be, but on the Main Bios Screen, there is list of drives beginning with a Primary IDE Master & Slave, but then it jumps to the Third IDE Master, forth & so on. There is no secondary on the list. My hard disk is connected to the secondary connector on the mobo, and so it is not in the list.
I had to connect my DVD to the primary, otherwise I couldn't get Windows to load. This is the only device shown in this list.
In the Boot Menu of BIOS, I can see a both IDE devices by name - both the HDD and the DVD.
When I try to install windows, all the stuff loads into the Memory, and then it says it can't find any hard disks.
