messerchmidt
- Nov 2, 2005
hi all, just upgraded my friends pentium 4 3.2ghz system to a core 2 e6300 and I am having stability problems.
He had a s775 pentium 4 HT @ 3.2, msi mobo, 1gb ddr1, ram, x850 pci-e,etc
was abit slow for photoshop and avid xpress so we updated it
We used some of his old parts, this is the systems specs.
core 2 e6300
coolmaster hyper 48 (taken from his old system, used artic silver 5)
Asus P5B Vanilla (they did not have the deluxe in stock)
2GB Cosair value select DDR2 667 (1gb x2) [ram overclocks like a demon]
ATI x850 PCI-E (used from old system)
onboard sound @ HD mode
onboard gigabit nic (DISABLED)
Segate 320gb 7200.10 SATA-2
panasonic DVD-RW on the IDE channel
Lanli case with 4 fans
Silent 380w PSU (I think its an enermax)
Dlink DWL520 wireless-G PCI (bottem slot)
Adaptec firewire PCI (2nd lowest pci slot)
Dell 24inch LCD
Even at stock speeds, I am getting random lockups on this system. Not even at full load, just while browsing the net or using photoshop.
I also cannot get the system stable over 3.15ghz (450fsb)
I got the latest bios, set the ram divider to 533 (1:1), did all the bios mods that were needed,etc for it to overclock.
I ran prime 95 for over 8 hours, no problem. But I am stillg etting random lockups. Driving me nuts. I am thinking
1) bad bios flash
2) PSU not putting out enough juice
3) bad board
I did not get the deluxe because they did not have it in stock. Any ideas what could be causing the random lockups here?
using winxp sp2 - reformatted afew times - did not load avid or photoshop,etc
just browsed web and bam - it crashed. any ideas?? HELP!
core 2 e6300
Dell 24inch LCD
1) bad bios flash
3) bad board
