DaRuSsIaMaN
- Apr 22, 2007
When I boot up the computer, it incorrectly identifies the processor. The POST says:
Main Processor : AMD Athlon(tm) XP 1150MHz
But when everything is correct, it should say AMD Athlon(tm) XP 1800+, since that's what I have. The POST goes on for a few more lines, but then I get an error that says:
Warning!! CPU have over speed
And it stops and doesn't boot up anymore. At another forum, I learned a way to fix it. *Kind of.* I was told to clear the CMOS, and I did that, and it worked. Everything went back to normal. But then the problem occurred again. Now I did the same procedure to fix it for a second time, and my computer is up and running now. But I'm afraid to shut it down, thinking that it will happen again... so how can I fix this?? And why did this problem happen in the first place?
I have an ASUS A7N8X motherboard, by the way. AMD athlon 1800+ processor ... should I list any other system specs? Any help greatly appreciated. Thanks!
