asus maximus formula?
Welshsteel
Hi,
I currently have a q6600 G0 on an asus P5B E Plus.
Its running completly stable at 440 x 8 or 3.52Ghz. I've just bought a quad so if my testing methods sound wrong please tell me how it should be done.
Tested this setting by running two lots of Prime95 and ran the test overnight which was just over 9 hours. Highest core temp was 69 degrees C.
Now, i have tried setting the Q6600 at a higher clock and it simply won't budge. Tried everything. More volts, slacker ram timmings so on.
My question is do you think i may be limited by the old P965 chipset?
I have been meaning to get a new motherboard and i think maybe the Asus Maximus Formula X38.
Will i see an improvement with this board and is this a decent board????
Any help would be great cheers.
it's a decent board, but I'm not sure you're going to get a higher OC than what you're running now. If you're going to get a 45nm CPU, I'd get the newer board, but if you're waiting for Nehalem, stick with what you have.
Thats a good point but i think the new x38 chipset is better for overclocking quads?
3.5Ghz is pretty solid for the quad you're running. I doubt you'd get more than 100mhz or so extra out of it.
A little personal experience. I had a B3 quad that only did around 3Ghz stable with my G33 board. I went out and bought a Maximus and ended up with the same 3Ghz OC and out $250. Personally, I doubt the board is holding you back all that much.
I have to agree. Even with an X48 board (the Rampage Formula, for example) I'd be surprised to see a huge difference from that overclock. The $250 or more that it would cost you could be better spent on a 45nm quad, which might hit higher speeds, or just not at all (it's an awful lot to spend for a relatively small or none at all increase in performance).
In otherwords, the Nehalem has high multi?
After alot of tweaking about i got the quad to boot at 4.05Ghz! Completely unstable though.
I then lowered to 3.87ish and ran 3DMark06 and a few other benches - However still not stable in Prime95.
3.7 for just now seems to be the sweet spot. I'm convinced this quad is a beast an capable of alot. Think its the temps that are holding the clock back at 3.87 during 3DMark06 cores hit 77:eek:
I've been wheeling and dealing on E-bay for a while now and haven't actually dipped in to my bank for a while. So... i bought a P5K Premium and the new OCZ cooler thanks for the advice anyways i may update when i recieve the stuff.
Cheers
