Asus M6G and Xeon
Phrik
With this setup...
Asus Maximus VI Gene + Xeon 1230 V3
...the Xeon 12x0 processors don't have an IGP afaik, so I would need a dedicated VGA right ?
Asus Maximus VI Gene + Xeon 1245 V3
...the Xeon 12x5 processors do have an IGP, so it should be alright without a dedicated VGA right ?
...I am thinking of switching to an ITX build. But then it would be a waste of the Asus board that I already have, and I thought maybe using that board to upgrade my server and get a new Xeon proc. Asus lists the 1230 V3 and 1245 V3 as compatible. I might go with the 1245, I just don't want to use a dedicated VGA.
The Asus compatibility list does have this mentioned on every Xeon processor:
*Intel Xeon Processor Family is designed for servers. Some features may not support when installed on 8 series chipsets. For more details, refer to ASUS support site at http://support.asus.com.
...just to confirm my uncertainty. I just never built a system combining a desktop grade board with a server grade processor. So, I'm wondering which features they are talking about, I believe ECC won't be available.
Cheers for any advise !
No ECC which might be a biggie. Does using a Xeon with Z87 chipset make sense?
ECC no biggie, I don't see the point of having that on what I want I'm using the server with. It's just a simple NAS, no RAIDs, but some VMs. If data goes corrupt, fek it, do it again, or restore from backup. Very rare occasion I would have to do any of this anyway.
Yes, it does make sense for me using a Xeon with my current Z87 board, because I don't fancy buying a server-grade board, and ECC memory just for a simple file server. An i5 or i7 equivalent of an 1230 V3 or 1245 V3 is a bit more expensive in the country. And since I want to switch to an ITX build, all I have to do is buy an ITX board, the rest I already have.
Why even bother getting an Xeon? Why don't you just get an i5-4570 or something for $189 or so (cheaper if you have a MC nearby). You're not going to be stressing it too much and an i5 with vt-d is probably good enough.
