ASUS M2N-SLI Mobo
Pacwageo
I recently purchased a mobo from NewEgg for a new system I am building. After connecting all the parts and connecting the power I realized that the computer doesnt turn on. I'm a little frustrated because the mobo has a green light on it that indicates proper power flow. This light was definitely on.
Every component I purchased was brand new from NewEgg so I know it's not a software issue (since nothing has even been loaded yet). The wierd thing about this whole situation is that nothing turns on. Fans, CPU, HDD... nothing. :( The power button doesn't do anything at all when I press it. (even though the green light is turned on, on the mobo.
I'm assuming this problem is corelated to my mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131013
The only things I have done so far is connect the components and plug in the power.
The rest of my setup:
4GB G.Skill DDR2 800 RAM
AMD X2 6000+ 3.0Ghz Proc
2x 250GB HDD
Sapphire X1950PRO Video Card
700W Tagan ABS PSU
Standard DVD CD Drive SATA
2x Internal fans (large fans 180mm +)
Has anyone else experience a problem like this? Any suggestions? *scratches head* If this isnt a mobo problem I apologize for posting it here.
I would guess you're having a case short or you didn't hook up your power button correctly on your motherboard. I'd take it out of the case, set it on your motherboard box, connect all the components, and then short the power switch pins and see if it boots outside the case like that.
