D
Deleted member 79192
Guest
I was wondering if anybody hear has heard anything good or bad about this motherboard. I plan on purchasing it soon as part of my computer upgrade I'm getting. Features I really like are the SATA II connectors, which I plan to use with a new SATA II hard drive, and I also plan on taking advantage of the Gbit LAN sometime in the future as well.
Here is a link with a picture and more info about the board:
http://www.tigerdirect.ca/applicati...ails.asp?EdpNo=2768826&CatId=2320#detailspecs
Furthermore, do you think that when using this with an AMD Athlon 64 X2 3800+ and an XFX GeForce 8500 GT I have a good balance between CPU and GPU power?
Thanks in advance for any advice.
