zzDarkwingDuck
- Nov 28, 2011
That little thing is crazy, I thought the noctua one seemed thin enough. Did a waterblock ever get released for the Asus 670 Mini?
If I run some benchmarks til my GPU gets up to 75C, there's a little warm air coming up between the HDD and PSU and out the top, warmer air coming out the rear of the top above the CPU cooler, about the same from the rear exhaust, and hotter still from the bottom rear PCI bracket.
Hey WiSK, just wanted to let you know that I ran this same "test" again tonight, but this time on an open desk instead of inside my mostly enclosed armoire desk (M1 was a few inches from a wall on the left and rear), and the majority of heat was actually blowing out of my rear 92mm exhaust. There was still a noticeable amount of heat coming from the bottom rear, but nowhere near how it felt before. The top front and top rear were about the same.
I moved some wiring tonight, but failed to notice whether or not I might've blocked off the blank PCI bracket at all.
Dunno. Obviously flawed methodology is flawed![]()
Wow, good find! If I read that correctly, it looks like CoolChip is commercially producing the Sandia radial cooler to be sold by CoolerMaster.. finally!
EDIT: And I hope they're actually making a retail CPU cooler for PC, and not just an Xbox-specific one.
I recall people fitting the short GTX 760 in the M1, so this should fit.
Can't believe there's still no english reviews out for this one yet. But I betcha damn well these dipshit tech sites will jump to be first to review the über-practical foot-long 960 Windforce with 3x fans..
Most PCs are still in the Midi-Tower size, and that card is going to be pretty quiet, I'd suspect.
Maybe.. but if they were going for quiet, you'd think a giant heatsink of the same size could passively cool the 960 silently without the three large fans.
..because they think that a larger card has to be better..
I think this card is targeted at people whoIt probably could, but the people this card is targeted at are the same guys that use 1000W PSUs on their single GPU and 100W CPU because it is "The real shit", or the guys that put a mITX board in their 60L tower case and call it SFF.
Guys like us, who want small and/or silent are far and few between.
Small, relatively cool and quiet, and as *powerful* as possible given the size.. I'd buy a tiny ITX-style 980 today, if they could make one![]()
I would like to see the PCB for that![]()
Grab a Titan Z and chop it in half.
As dumb as that sounds, that isn't the worst argument to make for the ability of realisation of a short GTX980.
A short 980?! *swoon*
At least a short PCB should be doable. Cooling is a completely different story. You'd probably need a 2.5 slot cooler to do that at least half-silent, and I don't think many mITX cases actually have 3 slots. The M1 would work, and my custom design, too, but that's probably about it.
My bet is that we're not going to see an mITX 980 in the next few years
We'll never see it. Even as the TDP lowers, there's no feasible intersection in the Venn diagrams of MITX and high-end GPU's such that a short *80 would make viable sense.
dino - how's the noise, subjectively speaking? I've got cash waiting to be spent on a vid card since I returned my first 970, and I'm thinking this guy might be the ticket for me.
that is one of the most important to me, ill have it in and stressed tomorrow and let you know. otherwise very solid build, backplate is plastic but feel solid. Heatsink is well crafted. I'll give performance info tomorrow as well as heat/sound.
