Asus Confusion
swank1
I am considering two boards for my next computer either the Asus M2N32-SLI Deluxe/Wireless Edition or the Asus M2N32 WS.
The main difference between the two is that the WS has two PCI-X slots, that I understand, but are there any other differences? I noticed that Asus says the SLI is LIVE! certified but the WS is not, which makes me think that something else is up, but I can't tell what it is.
Basically, does the SLI have anything that the WS does not (aside from different expansion slots and the wireless)?
the sli version if for enthusiast/home use
the ws is workstation class
i dont think you need the ws for any reason other than u can get the ws for cheaper
Well I would get the WS b/c I would like to have access to its PCI-X slots but don't really need them that bad. So, if there is a major tradeoff for them I would go with the SLI, but if I am only losing some PCI-E x4 slots, than it is worth it for me to go with the WS.
kirbyrj- They both use the 590 SLI MCP chipset, but the WS throws in the NEC uPD720404 as a PCI-X bridge
any updates? I noticed that the parts kit which comes with each is pretty different- the SLI comes with lots of stuff, like a MOSFET fan, SLI bridge, etc.
