Brand new pc, new proc, ram, etc. I have been building PCs for a few years so i think im out of luck however i'd like any ideas.
AMD3500+ 90nm
1gig DDR500 PC4000 Ballistix
X800XT (positive its working)
Antec 480 Neopower
Basically i was going to install a whole new AMD system into a somewhat complex water cooled case. However before i seat everything i simply wanted to make sure it would POST. Nothing ticks me off worse then setting it all up only to find something is bad and having to weave between hoses to yank it out. Plug all the stuff in (CPU has no cooler only a water block without water for the moment), reguardless all i need is for it to POST so, like my LG775 i figure it will boot without coolant for 20seconds. Nothing comes up on screen, it emits 1 long beep then nothing. Obviously i dont dare leave it on for any period of time over 15seconds with the CPU getting no cooling. I'v moved the memory around (yes its installed into B_1 not A_1) and even pulled the CPU as it should still post with an error. I get nothing. At this point im not sure if its the motherboard or a bad memory module. According to Crucials own chart the motherboard does support it so its not a problem of incompatability. It simply emits 1 long beep and wont do anything further.
Suggestions?
AMD3500+ 90nm
Antec 480 Neopower
Suggestions?
