Llama[Style]
- Mar 7, 2011
Yes... we all know the VRAM on the DC2T cards are f*cked... but here is confirmation straight from the horse's mouth.
E-Mail sent:
Response from ASUS:
E-Mail sent:
I have the latest bios for the card, I am using dual link dvi. I am
experiencing artifacting and display crashing(black screen), quite often.
I can play games for hours...no crash
I can be idle, browsing the internet, I will get a white screen (or
whatever the gradient my background is at the moment) and lines --
ultimately resulting in a hard shut down/reboot.
I can be playing games and it will crash within 5-10 mins of gameplay, or
instantly.
The black/gray screen is the most common, usually happens when I am gaming.
I've been logging my gpu-z and it shows that the card is not under any
stress and temps stay fairly low(avg 65~c). It is very inconsistent when
the crashing happens or artifacting begins.
I've tried *every* suggestion in the post I provided you. I do like the
card, because it does stay extremely cool... it just crashes A LOT.
Response from ASUS:
Dustin,
I would think that the VRAM is going bad on your card. That is, unless you have overclocked your card past stock settings. Especially since you have the DC2T model, any further overclocking may result in instability.
If you have clean drivers and you haven't overclocked, then it is most likely the VRAM and you would need to get the card replaced.
I can set you up with an RMA if that is what you would like, just let me know.
