I would just load up your OS and see if it still shows that
The only thing i can think of espically if its the same error code when you have no drives plugged in, basically the board is waiting for the next step which it cant do because there is no boot device.
error codes beats black screen or no posts any time![]()
It was on the Dr. Bug LEDis the 24 an error or a temp reading?
Well I have finished me build setup. I am not receiving anymore error readings(after entering OS). I am a first time builder and 1st time OC'r. Yet, I was able to get a successful OC. I cannot get the RAM to 3200+mhz. Due to my lack of experience and the touchy relationship between RAM and these type of boards, I settled on 2933 No OC on RAM and XMP enabled at stock timings. I got the r5 1600 to 3800. I did bump the SOC voltage to 1.1 but I am not sure I really needed too.
Not much of an overclock.I know this setup can do better.
I got close with RAM at 3200+(stock 3200 with XMP would not boot-gskill Flare X) I figure I might try again later on a new BIOS update.(currently 2.30)
Completed MEMtest86 successfully.
Completed a 20min LinX burn.
Completed 3DMark Time Spy Benchmark and their 10min Stress test.
Completed CPUz benchmark and outscored r7 1700 on single thread and r5 1600x on multi thread.
I will probably do more long term stress testing over the next few nights.
Thanks for all comments.
No I took all voltages back to auto and just have cpu at 3800 and RAM is xmp enabled at 2933 with stock timings and auto voltages. I am content with it for now. I will try later on. There is already ya new BIOS out. But I will wait for a few more months. This setup will handle everything I need atm.Yeah you should not worry about things like ram at this point in time , take another look a few bios revisions later.
Are you using stupid amount of voltage for ram ?
Ah ic. It just feels like it should work when I start tweaking settings to get the 3200. I am sure someone with more experience in this could get it working. I will probably try it on the 2.4 update or the next one. Hopefully one of these BIOS updates will make it work with just xmp and stock/auto settings for noObs like me.Yeah the newer agesa code for 1.0.0.6 came out for the asrock boards. I would give that a try. Not sure you should need it i heard great things about the Taichi and flarex. I can also tell you i have the asrock killer ac board and i loaded up the newer bios and it didnt help me get past 2933 either.
And you are right in that regard that if you can not get it to work without jumping through 200 different hoops and still don't have a stable result or a result which matches someone with nearly the same hardware why not wait until they do have a bios which is better or more flexible with the ram you have.
Supposedly 3200 should be less of a problem.Did you entertain the possibility that his chips IMC might be a little weaker than on other Ryzens' ?
3600 may never be possible for all people on this platform, even if you have an Intel-rated 4266 kit. Too many variables. 3200 is the doable zone for most CPUs/kits/boards. After that, things become more conditional.
If you get to 3600mhz it will be because you have a superior IMC on your chip, but it is UNLIKEY. Getting 3333mhz is doable. I could NOT boot to 3466 with my FlareX DDR4 3200.Here is a review from the 3200mhz flarex kit + your taichi on newegg.
Pros: - Works well with my Ryzen 1700/asrock taichi MB
- Good speed and latency
Cons: - None so far
Other Thoughts: Initially would only boot to 2933 XMP with my particular MB with older bios, just flashed to the AGESA 1006 bios and now runs at advertised speed. As ryzen matures and firmware improves these issues should resolve. After browsing the forums, there seems to be no sure fire combination that works despite the manufacturer QVLs, but these sticks seem to be among the best for ryzen compatibility. Make sure your bios is up to date no matter who makes your MB. Going to see how high I can OC these eventually, hoping to hit upper 3000's
