Hi everyone...
Alright so I found it obvious that it's the motherboard, not any other components.
So I got this motherboard(ASRock GM31-S) from my cousin, so I thought about building a small backup PC.
Since I have a 9500 GT thrown in my room without use, I put it in, it was never used before, in it's box.
1GB OCZ RAM
SUPREMEFX II Sound Card
435W PSU
160 GB Hard drive
...Anyway, I came to install a new clean copy of XP, first try I got an error message, that some file couldn't be copied, I skipped. And until I reached the installation of Windows XP, I get a "Fatal Error" at minute 39, which is 2 minutes away from installing drivers(37). Anyway, I restarted the system, and continued on, but chose to repair the windows instead. Then I got an another message, the same one(Fatal Error). I tried again and again, sometimes it would work, but I get a blue screen, or some purple, yellow, and white bits on my screen and the system gets stuck, things never changed, so I took off the hard disk and put it on my main PC, installed Windows XP, everything went fine, after ONLY installing XP, I shut down the system, took the hard disk back to my back up PC, and system runs fine, until user is logged on, I get purple, yellow, and white bits around my screen and system freezes(Btw, I also tried removing the sound card, switching the RAM, removing the 9500 GT and using onboard VGA, everything's the same).
I tried every component on my backup PC on my main one, everything works 100%...But for some reason, they won't do that on my Backup PC...
So I went in BIOS, disabled OC'ing and such stuff, but things were still the same...
Does anyone know what could be causing all this?
Please help me out, I don't like seeing stuff not being used while sitting next to me.
EDIT: Forgot to mention this; Sometimes while installing devices(On windows XP installtion), it gave me an error message saying something like The software for the following hardware did not pass windows logo test: Battery(when I tried installing using the backup PC, not my main PC)
I'm not sure of the message, but it's something like that.
Thanks in advance ;D
~TeeJay
1GB OCZ RAM
435W PSU
160 GB Hard drive
~TeeJay
