ASRock Dual Sata2 Problems.
Dinh
For the past few days, my mouse decides not to move on the XP logon screen, so I thought it was some driver conflict and reformatted. Hours later, still frozen. I went into the BIOS and disabled the USB Controller and everything started to work again, but I need USB!
AMD 3800x2
1GB Corsair
AsRock Dual SATA2
mx510 connected using USB -> PC/2 Converter
Should a BIOS Flash help?
Did you reenable the USB controller? Same issue? You could try a bios flash if there's a newer bios available. At this point it probably won't hurt it at all.
Yes, my mouse dies when USB is enabled. I tried plugging in a USB mouse but it acts like there is barely any power and flashes.
I've recently flashed the bios to the latest version, and same thing.
Nope. They worked recently before a reformat. I'm pretty sure I have all of the correct drivers.
Did the reformat kill it? I know there is a problem with SP2 and USB drivers (as in don't install any USB drivers or else you'll lose your USB controller).
Not installing the USB driver for the SATA2 board has given me problems in the past with USB devices.
-JP
They are all enabled, which produces the problems in the first post.
I this mobo about 2mo ago, my wife started having usb issues..it would reboot computer if anything was plugged into certain usb ports..fortunately and oddly enough the canon printer is not causing an issue..I think it is because the device is not getting any power from the usb port
memory card reader and usb hubcaue a reboot/lock up
I have flashed the bios..not sure about newest...I also down clocked..no more ocing...but usb issue persists
Issue Fixed, thought another one arose.
When ever I plug in another my USB Camera, my USB mouse stops responding, so I have to unplug the camera for it to work.
Nevermind that. Those same problems came again.
Just tried :
Disabled USB Controller
Reformatted XP
Install Chipset Drivers (no ULI USB here)
Enabled Controller and let XP install its own drivers
Now,I a huge USB connect/disconnect loop and then the mouse stops working
Alright, narrowed it down to the drivers!
ULI doesn't have any USB drivers for XP since SP2 has USB2.0 Support already.
I let windows install its own default drivers, no workie.
Tried the ALi one, was in the compatability list during picking out the drivers. No workie.
Now trying to find the damn drivers -_-.
