Snappshoota
- Jun 8, 2005
Well I bought this mobo on thursday
Was trying to get it up and running with, AMD x2 4800+ , 1gb stick of rendition DDR2, 80 gb WD IDE HDD, and a Antec earthwatts 430.
Plug everything in, power it up and bios loads, detects everything. So I throw a copy of windows in the cheap lite on dvd rom, load into bios change to boot to cd. Restart, and this is where the hell begins.. After restart I have no video from the onboard (and no other PCI express card to use) and I notice that the HDD and the Dvd rom dont boot up like normal. Just the CPU fan is spinning.
So I switch off the power Via PSU and let it sit a few. Power back on and video is back, load up windows cd, get through all of the format, and half way through coping system files and the system restarts and no video again....
I install windows with the use of another pc, swap the HDD into the asrock system, load up and brings up windows did not start properly screen. Hit load windows normally and system restarts and back to same screen. I choose safemode and once it gets to drivers/Mup.sys it restarts and goes back to same screen...
Gettin really fed up. between the video only working when it wants to, and not being able to load into windows..... Getting ready to throw the damned thing out the window into my pool..
Any one have any clues??
