Asrock 939Dual-VSTA - Voltage issues?
whitmell
I just got one of these mobos and tried to turn it on - I got a quick spin of the fan (just a split second), and that was it. I was using a Fortron 550W power supply, that has been reliable for the last 2 years running an ABIT KT7A-RAID w/ 4 hard drives, 2 DVD drives, and a full PCI bus. I had to get an adapter for the 4-pin 12V connector on my motherboard, and that came right out of one of my regular molexes. So just to test, I got a 500W power supply from CompUSA, and it works just fine.
I measured the 12V rails on my 2 PSUs, the Fortron was 12.21, and the CompUSA was 12.39. Could this be why? Is it possible my BIOS is configured to use a higher voltage, and if I turn it down a bit, I could use the other PSU? I'd really rather use the Fortron, as I trust it more than the CompUSA.
I think both supplies are ok, try again with the minimum you need to boot, memory, vid card , remove or disconnect everything else.
Are you dead certain the board is mounted properly on the standoffs? If there is any doubt take it out of the case and try to power it up, if the leads for the power switch are not long enough you can momentarily just short the contacts with a small screwdriver etc.
what voltage is you memory rated for ?
Yeah I tried all that, no dice. I posted this on a couple of other forums and they suggested that the current from my 12V rails on the Fortron PSU was insufficient, which I should have tested. And will, when I get home in about 20 mins. I will also make sure my RAM's set at the right setting, and once I get it right, I'll try it w/ my Fortron. Thanks!
measuring DC current is NOT a trivial matter. Carefull.
ohhh I was assuming you were using a conroe core which compared to the old P4's doenst take nearly the juce to get going. What cpu are you using ?
64 3200+ Venice.... and don't worry, I've got a nice DMM and some solid electrical experience.
