The ATI 3xxx series of cards have never had the problems that the Nvidia PCI-E 2.0 cards had. They all work with the PT880Pro/Ultra boards without any flashing (albeit with their own driver issues).
instago said:Will the XFX GeForce 8800GTS 320MB PCI-E Video Card work with this motherboard? On the supported list, only the MSI 320M model is listed, but is the XFX 320M model supported? And what about the more recent 512M versions of the 8800GTS?
Asrock Response said:Dear ASRock Customer,
It should also be supported.
Thanks for contacting ASRock.
Yours truly,
ASRock
eVGA has redone the BIOS on their G92-based cards, that is, the 8800GT and the 8800GTS 512. They no longer need a BIOS flash to work properly with your board. Older G80 cards from any vendor, including 8800GTS 320, 640, and 8800GTX, should work without issues. All will suffer some speed degradation vs. their full potential, but then so will any other high end PCI-E card on this board, including those from ATi. They will still be faster than slower PCI-E cards on this board--it's a proportional thing. If that's not good enough for you, your only way around it is to buy a better motherboard.I just got an email from Asrock Support stating that non-MSI 8800GTS 320M models should work along with 8800GTS 512Ms, but after reading through this thread and many others, it seems that this isn't exactly the truth (as far as the 512Ms go). Plus, I've seen people say that the 8800s perform very poorly on PCI-E 4x slots, even worse than HD 3870s, which leads me to believe I'd be best off getting the ATi card as it performs well on this board and is fairly cheap. I'm still not sure that's the best choice, though. Any suggestions? By the way, I don't want to have to do the Gen2--> Gen1 flashing.
Here's my question & Asrock's response:
Thanks, Stick. Are gpu fans rated to last longer than cpu fans or vice versa?
Thanks,antix12Water1 I placed an order for a 4850 two days ago. I should be receiving it in the next few days and I will report on if it works with the 4coredual mobo.
Wow! Thanks Condi!
That makes my decision easier. I think I am going to get the 4850 and try running it on my 775DualVSTA. I can't imagine it will work, but I can't resist trying..
If it doesn't work I will just get a new MB.
This is encouraging though!
Thats what I thought to. Hope I thought right...775Dual-VSTA is basically the same board as 4CoreDual-VSTA. From what I've read the only difference is that the Northbridge on the 4Core is overclocked so it officially supports 1066 MHz FSB CPUs. In all other aspects the boards are identical, so one would assume that whatever works on the 4Core works on the 775 as well
I'd like to see the 3dmark06 scores of one of these 4850s at 1680x1050 4xAA on a 4coreDual or 775Dual. I'm getting 7000 from my 8800GTS SSC which is decent for such an old board- i'd expect the 4850 to get near 9000.
