ASM1061 or 88SE9215 ???
SoManyBits
Hello,
One of my systems has an old Gigabyte Motherboard GA-P67X-UD3-B3
I would like to add two or more SATA 3 or eSATA3 ports.
I only have a one lane PCIe slot available to me.
There are a variety of controller boards on the market for PCIe 1X.
The ones I seem to find most commonly either have AsRock ASM1061 or Marvell 88SE9215 chips.
I will be using 7200 RPM mechanical drives and given that I can only use X1 slot, speed is not really an issue.
What I am wondering is which of these chips would be more reliable in service?
I do already have Marvell drivers loaded for the 88SE9172 that is embedded in the motherboard.
Thanks for any suggestions you can offer.
Hi,
came along this thread having the same question 4 years later. Did you already chose one? If so which one?
Currently bought an 9215, while having asm1062 onboard. Wonder if asm1061 card would be a better fit.
Hi,
I don't think it would make a difference as long as they play nicely together in your system. I think both of them are going to be limited by the x1 bandwidth with multiple drives attached.
I've used both the 9215 and the asm1061 and never really noticed a difference between the two.
