Asking for advice about SFF build.
Haplo_09
Hi everybody.
I am planning to upgrade to SFF and woder those with experience can help me decide with the build.
mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128078
how good is it at overclocking?
hard drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262
processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115052
I wonder will it be overclockable with above mentioned motherboard.
memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
is it good for oclocking or do you have better ideas?
Also, what is the most efficient CPU cooler one can fit into this type of http://www.newegg.com/Product/Product.aspx?Item=N82E16811144109
I have build SSF 3 years ago, but things changed since then.
The motherboard is semi-decent for overclocking. Just don't expect too much. At the very least you should be able to get a 3.0Ghz OC with the E7200.
The G.Skill RAM is just fine. Excellent choice even.
I'd spend the extra $2 for an extra 70GB of storage and potentially Raptor-like performance:
Western Digital WD3200AAKS 320GB 7200RPM SATA 3.0Gb/s Hard Drive - $62
Oh and if you're planning on keeping that Apevia case, DO NOT USE THE INCLUDED POWER SUPPLY! Apevia makes some of the shittiest PSUs in the world. If you want a dead system, use that Apevia PSU. Otherwise get a quality PSU. I recommend this PSU:
Corsair 450VX 450W PSU - $70
Oh and if you don't feel like paying for a PSU that you won't use at all (the Apevia), get this case instead:
Silverstone SUGO SG02W-F White mATX Case - $75
Are you gaming on this system? If so, what graphics card will you be using?
actually I have chenming, which slightly different desing and better PSU..
but thanks for advice. Also, any ideas about alternative motherborads that have better overclocking options.
Oh and yea I plan to do some gaming with asus HD 4850 .
I can vouch for the WD 320GB. Those hard drives have excellent performance and I am 100% satisfied with mine. They are also near silent. I have a 1TB one in my external enclosure and compared to those 320GB ones I hate it. Very noisy when read/writing.
I would suggest going with that Asus motherboard he linked. I am kicking myself for not buying it now.
