Which one gets you lower temps?
How come other thermal pastes, such as Thermalright Chill Factor paste, the manufacturer says to spread it out evenly over the IHS with a card or finger + baggie?
Is the line method exclusive to AS5?
It means that either your heatsink, CPU, or both are not flat. That's why you should use the line or blob method; the clamping pressure will squeeze the TIM into all the empty spots and make sure that it fills in as many gaps as possible.Does that mean my TRUE is concave as hell and needs to be lapped?
AS5 has the consistency of week old pudding, thats why the application methods differ from other brands. I've always put a dab in the middle and let the heatsink do the work. They say you shouldn't, but i've been using this stuff since it came into existence and always used the same method.
