I was playing Painkiller today and everything was great. I made it to the snow covered bridge level and a good majority of textures had this rainbow effect to them. I took a couple screen shots below.
One from FarCry too...
I havent had my card overclocked since Quakecon ( Default speeds are 425 , 1200 ) CPU can run prime all day and night. Im using the 66.00 Beta drivers. Fastwrites are off , my power connections are tight , I reset my bios to all of the default settings and still the artifacts remain.
I have noticed in the last month or so while playing games sometimes I will just get a tiny blip accross my screen. Its hard to describe. You know when your watching a video on a VCR and the tape is damaged and you will get like a static line through the screen? Thats whats been happening to mine too but only for a split second.
I dont know if you all have seen anything like this before or mabye have some suggestions for me. Im thinking I might have to RMA the card
. Specs are in my sig , Thanks in advance for the help.
