Artifacts and bright colored spots
bl00dsh0t
Well about 3 weeks ago I started getting strange stretching of textures, flickering ground/sky, and pinkish lines across the sky while playing WoW.
A little history: I used to overclock my card with Coolbits (using detect optimal settings) and it seemed to work great, no excessive heat, locking up, or strange activity. It was fine for probably a month or two and then this showed up, but at the time these artifacts started appearing I wasn't even overclocked.
I've checked my temperature while in game and usually stays around 65C, and I've also switched out my video card for my brother's card which is the exact same model. I also tried switching out my power supply with a spare I had laying around, but no luck. My system temperatures are also just fine (usually around 40C idle and 50C at load).
I've tried playing BF2142, and I still get artifacts. One thing I have noticed though is when I load WoW my desktop wallpaper which is black will start popping up bright spots that kinda look like dead pixels. And once the game is fully loaded and I've been in awhile I usually have about 10 total on my screen.
I'm currently at a loss because I don't have any other spare hardware to try, nor do I know what else I can try. I run virus scans and spyware scans from multiple programs, but to no avail.
Does anyone have any ideas on what else I can try or what might be the culprit here? Thanks.
My current setup:
e6400 not OC'd
Gigabyte GA-965P-DS3
MSI 7900GS
OCZ Platinum 2GB ram
Seagate 400gb SATA II
Creative Audigy 2 ZX Gamer
Take a screenshot while the problem is occouring, and post it here, that way we can see if it's your monitor or something else. It sounds like a card that's on it's way out, but I'm assuming you had the same problem with your brothers card, soooo...
I'll take some screen shots tonight since I'm at work right now, but yeah his card did the same thing. Although not the exact same, artifacts yes but his displayed the pink lines all over. I mean they are the same exact card that we got on Woot, and before he upgraded he said he saw a few artifacts.
I think it might die.
But how come if I hit the case the pattern changes?
and also I did get some artifacts from a different GFX card?
Also what I find interesting is that I can take a screenshot of this! - so it must be in memory corrupt like this?
If it the same thing happened with your bro's card, it could mean that you have a monitor problem. If possible, use another monitor. If you still get artifacts, then the vid card is dying.
I just tried the graphics card in another machine and get the same artifacts. So the card is deffinately dying.
However when I tried another card in my machine it showed a couple of "spec's". Not the same repeated pattern as I get with the dying graphics card, but still some corruption.
Any idea what that could be?
If I am 100% sure its just the card I will replace the card. But if its more I dont want to waste the money on old tech (AGP).
