ok some chime in,
here is the situation..
i have teh 42w2 LCD Monitor (1920x1080)
i've had it since january and it has worked great..
the other day something happened where i was no longer getting the bootup screen, but it would eventually come on after vista booted up fully..
a month passed and i decided maybe i would try a new video card (i had an HD2400 in there)..
i put in an 8400GS and i dont' get any picture what-so-ever, even after vista boots..
i went through the regular checks, i got my 2005FPW and everything worked great, i tried the VGA on the 42w2 and that worked fine.. it was only when i used the DVI/HDMI outputs that it didn't work on the 42w2..
i hook up the dual monitors and sure enough the video card wasn't detecting the 42w2 when connected to the DVI outputs (even tried different cables).. it only detected it as an "analog monitor"..
anyways to make a long story short i started to really think and it seems that the 8400GS is only a single-link DVI where all my other video cards are dual link.
Would i be correct in assuming that its the "Single Link" part of the DVI that has gone out on the 42w2. Which kindof make since that, that is why i dont' get a picture on the dual link cards until vista nd the drive is loaded..
anyways i got the bestbuy technician out (under the westinghouse warranty) and he really gave me the guilt trip that nothing was wrong with the TV (his digital output test worked fine) but when i asked him if he could specifically test the ED-ID information he told me No. (which is where i put my bet that is what happened)..
has anyone had any similar experiences with anything like this?
i am really thinking that without the ED-ID information over the DVI, the video card won't output any signal.. and with the dual link, it gets that ED-ID when the second link is initialized?
so to summarize..
2005FPW works fine on multiple computers over VGA and DVI
42w2 works fine over VGA from same computers
42w2 only works on dual link after vista booted up , no singal on bootup or with a single link card
the 42w2 used to work flawless on dual link cards (bootup image and everthing) until 3 weeks ago..
am i correct and justified in assumming something is wrong with the 42w2? i'm just a little irritated the best buy technician gave me such crap about it (he ended up ordering the board anyways)..
i really hope it fixes it for 1200$ i'm going to be a little upset if he concludes there is nothing wrong with the TV..
so to summarize..
