Areca Failed Volume Revived
I gotta say I was kind pf plesently surprised by this. I use 4 cheap as hell OCZ SSD's in my server that I use mainly for reads. I got an email notifying me that the SSD volume had failed (its in raid0). I ssh into my server thinking its gong to be possibly dead due to the volume rejecitng reads but to my plesent surprise its ok and cli64 lists the volume as ok. I look at the event history and I see:
Code:
Date-Time            Device           Event Type            Elapsed Time Errors
2010-03-26 02:57:15  4xOCZ SSD CORE 2 Rebuild RaidSet
2010-03-26 02:57:15  SSD VOLUME       Failed Volume Revived
2010-03-26 02:57:15  IDE Channel #09  Device Inserted
2010-03-26 02:57:08  IDE Channel #09  Device Removed
2010-03-26 02:57:08  4xOCZ SSD CORE 2 RaidSet Degraded
2010-03-26 02:57:08  SSD VOLUME       Volume Failed
2010-02-23 07:06:00  H/W MONITOR      Raid Powered On
So it looks like one of the SSDs reset and thus the volume was failed for a short period of time and then it revived itself. I got a couple read errors in dmesg but otherwise the system kept running as usual:
Code:
sd 0:0:0:3: [sdd] Unhandled error code
sd 0:0:0:3: [sdd] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
sd 0:0:0:3: [sdd] CDB: Read(10): 28 00 0a dc b9 58 00 00 08 00
end_request: I/O error, dev sdd, sector 182237528
sd 0:0:0:3: [sdd] CDB: Read(10): 28 00 0a dc b9 20 00 00 08 00
end_request: I/O error, dev sdd, sector 182237472
arcmsr0: block 'read/write'command with gone raid volume Cmd = 28, TargetId = 0, Lun = 3
sd 0:0:0:3: [sdd] CDB: Read(10): 28 00 0a dc b9 28 00 00 08 00
end_request: I/O error, dev sdd, sector 182237480
sd 0:0:0:3: [sdd] CDB: Read(10): 28 00 0a dc b9 30 00 00 08 00
end_request: I/O error, dev sdd, sector 182237488
sd 0:0:0:3: [sdd] CDB: Read(10): 28 00 0a dc b9 40 00 00 08 00
end_request: I/O error, dev sdd, sector 182237504
sd 0:0:0:3: [sdd] CDB: Read(10): 28 00 0a dc b9 48 00 00 08 00
end_request: I/O error, dev sdd, sector 182237512
sd 0:0:0:3: [sdd] CDB: Read(10): 28 00 0a dd b0 28 00 00 08 00
end_request: I/O error, dev sdd, sector 182300712
sd 0:0:0:3: [sdd] CDB: Read(10): 28 00 0a da e4 c8 00 00 08 00
end_request: I/O error, dev sdd, sector 182117576
arcmsr0: abort device command of scsi id = 0 lun = 3
I gotta say I am pretty impressed that the machine was able to just keep runing as if nothing happened.
Channel #09 was MIA for 7 seconds. I wonder if it was 8 or 9 seconds if the result would have been different...
Damn I just had this happen again. Those SSD's have been working fine in my server for 2 months and all the sudden I get this twice on different drives. I hope the drives aren't flaking out...
Code:
2010-04-01  04:27:40    4xOCZ SSD CORE 2    Rebuild RaidSet
2010-04-01  04:27:40    SSD VOLUME          Failed Volume Revived
2010-04-01  04:27:40    IDE Channel #11     Device Inserted
2010-04-01  04:27:33    IDE Channel #11     Device Removed
2010-04-01  04:27:33    4xOCZ SSD CORE 2    RaidSet Degraded
2010-04-01  04:27:33    SSD VOLUME          Volume Failed
2010-03-26  02:57:15    IDE Channel # 9     Device Inserted
2010-03-26  02:57:08    IDE Channel # 9     Device Removed
Did you ever resolve the issue with your OCZ SSDs on the Areca? I've got a Raid-0 with 3x120GB vertex that started giving me the same error a couple of hours after starting a migration of my stripe size on one of the channels. The array had been running for about two months with no error.
My error is only occuring on one IDE channel, so hopefully it's just a bad disk that I can send back for replacement.
I am still waiting on one of the forum employees but things dont look good. Interestingly enough it was the other two disks (10/12) that failed as 9/11 that were dropping out ended up being the ones that stayed alive.
