Hi All,
I am running an Areca 1880i (FW version 1.48B, BIOS 1.22D) with an HP SAS expander (FW v2.02) and 11 Hitachi HDS722020ALA drives. The 1880i is connected to the HP SAS expander with two cables. The HP SAS Expander is connected to a Norco 4020 backplane (with SAS to 4x SATA cables). The drives were all 1 large RAID6 array with no hotspare (128K stripe size, 16K clusters). In the Areca boot time BIOS unfortunately it does not appear that I can pull the member disk sequence; all I have is a screenshot of how it looks currently below.
This evening while I was out, I came back to hear the server beeping loudly, two drive slots blinking and the server hard locked. I hard shut it down and booted it back up. Much to my alarm the RAID volume was not accessible. I fully shut down and rebooted several times but the RAID Set/Volume appears to be missing. Besides shutting down/rebooting a few times I have done nothing else except look at the controller BIOS or web UI. Below is what a picture of the web GUI looks like now (there should be one large RAID6 volume with ALL the drives in it):
http://i.imgur.com/2ngAyl.jpg - Link to larger version of picture below
Here is what the RAID controller event log looks like now (the text as well as a couple of pictures):
011-10-30 22:25:36 192.168.001.002 HTTP Log In
2011-10-30 22:02:38 RS232 Terminal VT100 Log In
2011-10-30 22:01:53 H/W Monitor Raid Powered On
2011-10-30 21:56:13 192.168.001.002 HTTP Log In
2011-10-30 21:55:06 H/W Monitor Raid Powered On
2011-10-30 21:53:52 192.168.001.002 HTTP Log In
2011-10-30 21:50:29 H/W Monitor Raid Powered On
2011-10-30 21:50:19 192.168.001.002 HTTP Log In
2011-10-30 21:47:03 192.168.001.002 HTTP Log In
2011-10-30 21:45:47 H/W Monitor Raid Powered On
2011-10-30 21:32:15 RAID6 2TB DRIVES RaidSet Degraded
2011-10-30 21:32:15 ARC-1880-VOL#001 Volume Degraded
2011-10-30 21:31:56 Enc#2 SES2Device Time Out Error
2011-10-30 21:31:52 Enc#2 Slot#13 Time Out Error
2011-10-30 21:31:39 Enc#2 SES2Device Time Out Error
2011-10-30 21:31:09 Enc#2 Slot#11 Device Removed
2011-10-30 21:31:09 RAID6 2TB DRIVES RaidSet Degraded
2011-10-30 21:31:09 ARC-1880-VOL#001 Volume Degraded
2011-10-30 21:31:05 Enc#2 Slot#11 Time Out Error
http://i.imgur.com/a1K5gl.jpg - Link to larger version of picture below
http://i.imgur.com/wVpHpl.jpg - Link to larger version of picture below
What should my next move be? Should I try to rescue the RAID set? I want to be as careful as possible of course so I wanted to ask here before I started blindly doing anything and make my situation worse. Any help would be HIGHLY appreciated. I would be happy to provide any information you require; thanks in advance for any feedback/suggestions.
