Hello:
Wanted to see if anybody might have clues on next steps on recovering data on a ARECA 1220 RAID 6 raidset/volume? The situation is as follows:
I have a RAID6 setup with 8 disks of 2TB each, giving me 12TB usable.
Probably about 5-6 months ago, one of the disks started going in/out of the raidset, triggering rebuilds every 1.5-2 months. Being the (sadly) lazy person that I was, I did not pull out that drive, so rebuilds happened maybe a total of 4-5 times. No biggie I figured.
Just last night, the same same rebuild happened, but this time, unaware to me, the raid set configuration + volume config all disappeared from the areca raid card. The event log just showed a rebuild getting started about 5-6 hours ago, but when I tried to access the volume, it hung. So I ended up rebooting to get to the console and saw that all of the raidset info was gone.
My best guess is that the raidset rebuild did not complete and something happened (maybe that bad disk went bad again??) that caused the raidset config to disappear from the card.
Anyways, I ended up shutting off the box and starting up, and the disk that was bad showed up again.
At this point, I did a few google searches and saw that I could recreate the raidset without a re-init. So I promptly tried that, using a few config variables that I thought I had used previously (64bit LBA vs. 4K blocks, and 64K stripe size vs. 128K). Unfortunately, in all of those cases, a volume check reported a ton of errors.
So wanted to get opinions on next steps? Thinking that I may be able to:
1) Take out the flaky drive, and see if I can force the raid card to be in a degraded RAID6 nodes with 7 disks instead of the expected 8. (??)
2) Leave that drive in and see if we can continue the rebuild?
No clue how to force either of the above tho.
Probably I also need to first find out which settings I had my original raidset set up as - 64bit LBA or 4K blocks, and the strip size). Is there a tool that can help identify that for me?
Thanks in advance for any help,
Peter
Peter
