CaptNumbNutz
- Apr 11, 2007
I'm aware of this. The problem was that 65C was the number you had to look for when overclocking because it was a "soft" limit. 65C, wherever that sensor was uncalibrated or not, meant that certain parts of the chip were nearing their temperature limit (presumably around 100C). This was all anecdotal and varied, but the general rule of thumb through trial and error was around 65C.The temperature reported had nothing to do with reality. So no, the limit wasn't 65C. Just as you can find them long under ambient temperature or a heatsink with a higher temperature than the chip. They use uncalibrated sensors that could just as well show the value in bananas. However they do the job perfectly for what they should, the delta towards the max. Sensor location is also different for that matter.
What I wasn't aware of that it was measuring the Delta, and not just the temp of that particular spot. I guess that makes sense that if the chip was idling in the 30's-40's, then 60C+ would put it near 100C.
