Are These Temps "Safe"?
-x-th
I've never monitored my mobo temps until recently, and I want to make sure that my temps idle and under load are "safe" and within range to ensure the longevity of the board.
ASUS Rampage Forumula
(Monitored using Everest Ultimate Edition)
Load:
mobo: 38C
NB: 40C
SB: 39C
Idle:
mobo: 31/32C
NB: 36C
SB: 36C
Are these temps within the "safe zone" for this/a board?
Not sure how "sensitive" the NB/SB or general mobo are to temps, and what's considered a good safe range.
Thanks in advance for your feedback.
Perfect.
Although the temp monitor is probably off a bit, those are great temps.
Anything below 45 C on anything on your board is great.
Perfect.
Thanks for the response and info.
If the temp monitor is off a bit, by how much could it possibly be off?
Reason I ask... if it's around 5C+ off, then I'd be approaching/hitting the 45C mark, and if anything below 45C is great/best as you've said, then I'd like to make sure I keep it in that range.
Thanks again.
A lot of boards chipsets can get so hot you can't even touch the heatsink, and they still operate fine. You're temps are great. I wouldn't worry about it.
