Are these my real temps?
Hardcore
Just installed my first water cooling setup. Is it possible I'm getting these kind of temps? 10 degrees idle? Seems really low. This is not overclocked and the temp reading in everest are the same as the bios.
Field Value
Sensor Properties
Sensor Type ITE IT8718F (ISA 290h)
Chassis Intrusion Detected Yes
Temperatures
Motherboard 15 °C (59 °F)
CPU #1 / Core #1 11 °C (52 °F)
CPU #1 / Core #2 10 °C (50 °F)
Aux 31 °C (88 °F)
Seagate ST3120026A 23 °C (73 °F)
Cooling Fans
CPU 4355 RPM
Fan #4 1860 RPM
Voltage Values
CPU Core 1.15 V
+2.5 V 1.98 V
+3.3 V 3.36 V
+5 V 5.03 V
+12 V 0.19 V
+5 V Standby 5.08 V
VBAT Battery 3.07 V
Well, at max it's probably 15-17 celcius in the room. Case side is off and in the open.
My thoery is that the digital thermal sensors that core temperatures are based on are not accurate at very low idle temperatures. With low core voltages ( 1.10 v to 1.15 v ) and low MHz I see about 3C below ambient at idle. In theory that's impossible with air cooling.
At higher temperatures where the DTS was actually designed to operate, SpeedFan 4.32 core temperatures are very accurate. Don't pay too much attention to idle temperatures. Load temperatures are much more important to keep an eye on.
try coretemp, or intel tat to get more realistic readings.
with a GOOD water cooling setup, you will see ambient idle temps, with air you won't. Being below ambient is impossible with air, and only semi-possible with a bong evap water system.
Im just a noob but, isnt it possible with a tec block, or am i talking out of my ass again?
I must be thinking of sticking their CPU's outside in the winter :D
I swear some guy had his proc below ambient with air cooling, I forgot how he did it, but it wasn't phase-change or water-cooling... It wasn't a real setup, just a joke/gimmick
Oh well
Well, I have been running for a while and the temps are more normal. e4300 oc'd to 3.2 ghz and it is running under load max 37 celcius.
Much happier with these temps even though they are a little higher LOL. I still have crazy low idle temps. 18-20 max idle. I love cool rooms
It's possible to cool below ambient temps with air cooling, well below ambient. Billparish through an idea out to me about using a concentrated spray of Dust-off. Spraying directly onto the cpu heatsink could very well bring the temps below ambient. ;)
Those temps aren't realistic unless you just turned on your setup and filled it with cold water from the fridge.
That's just ghetto phase change
