Are there any socket A PCI-E mboards?
rbarr110
I want to buy a new vid card (BFG 6800, non GT), however, the place I need to buy the vid card (Best Buy - gift cards) I want only carries the PCI-E flavor. I was thinking that maybe I could find a new motherboard that is Socket A and has a PCI-E slot for the new vid card to minimize an upgrade expense.
A new mboard for $100 +/- is in my price range and a new mboard and cpu combo to go Athlon 64 really isnt.
Thanks
Nope. Socket A is a retired platform and there are no chipsets for Socket A with PCIe support. You'll need to go to Socket 939 for that.
Negative, NF2 does not have the architectural capabilities to handle such a demanding standard.
looks like you should just go Agp this time , theres really no advantage to Pci-E besides Sli and i know you cant afford that ;)
Check out FS/FT forums or check the Hotdeals. Sometimes they have good deals on AGP cards. Although if you're looking at Bestbuy for a video card, chances are you're not the FS/FT type of guy :cool: .
http://www.newegg.com/Product/Product.asp?Item=N82E16819104226
AMD Sempron 2600+ Palermo 800MHz FSB 128KB L2 Cache Socket 754 Processor - Retail
$74
http://www.newegg.com/Product/Product.asp?Item=N82E16813135190
ECS NFORCE4-A754 Socket 754 NVIDIA nForce4 ATX AMD Motherboard - Retail
$66.25
$140.25 + $1.98 shipping <--- not an overclocking beast by any means but I think this is the cheapest you'll get for a PCIe solution and it gives you the ability to upgrade all the way up to a A64 3700+ in the futue.
If you can squeeze out about $20 more, you could get a motherboard by MSI if you don't trust ECS.
Not 100% true, there are nearly a dozen Socket 754 boards on Newegg with PCI-E x16 on them.
At this point, 754 might as well be dead... so 939 it is.
desrin said:
this board will work
http://www.ecsusa.com/aboutUs/pf88.cfm
its pci-e and can handle Intel, AMD, or AMD 64 on one motherboard
Personally, I don't use "ECS" and "work" in the same sentence. ;) I'd spend a few more bucks on a board whose manufacturer has a lower RMA rate.
P.S. Trying to handle multiple different processors like that on a single board almost certainly means they've compromised somewhere in performance or in stability to do it. Looks like a major kludge to me.
From watching the demo, I didn't gather that it'll support Socket A processors, correct me if I'm wrong. It said Sempron but I think it meant S754 not A.
I think that what I posted earlier is probably the cheapest you can get away with for PCIe but it would require both a proc and mobo upgrade.
Er, I am keeping up with 3.8ghz P4s and 3500+ cpus thank you very much.
And I have 256k Cache with no Dual Channel gimmicks...
Well, I understand where you're coming from with the s754 dead statement, but the mobile scene should keep it going until they move the mobiles to a different socket. Not sure when that will be :confused: .
