adrenaline0210
- Aug 4, 2006
ok guys need help major... got a thermaltake tsunami case...i purchased a 240gts rad... plan on taking bottom drive bays out to have pump down below. Need to know where to mount my rad. Im thinking on cutting a cple 120mm size holes in the top or just a full rectangle to allow for airflow, then mounting the rad ontop of case, then 2 120mm silent fans ontop of rad and run wiring down a seperate hole.. having tubes run straight down into the case. Or i can possibly mount the rad in the top front of case sacrificing a drive bay...
Next i bought this res http://www.frozencpu.com/ex-res-83.html?id=YN5zys2u, main prob is i was going to mount it at top somewhere on outside, possibly the backside, but the way it is the 2 holes inlet and outlet are on the opposite sides, so i need to have a 90 of some sort to put the tubes back into the case... please help with suggestions... i need it to look nice too.
