cornelious0_0
- Apr 6, 2003
Well, seeing as this run of tests really didn't take that long, I thought I'd let you guys know what I found.
What I did was take my CPU and video card, clock them both down to stock, and run Aquamark3. Then I slowly started to raise the FSB, 5 at a time, recording the GFX, CPU, and Overall scores each time I did. Once I reached the 270fsb mark (where my 2.8C craps out on air cooling) I restarted the testing, and did the same thing with the 6800GT clocked at 425/1100.
My goal here was to try and find out when/where the CPU bottleneck imposed on these cards starts to wittle away. This can be done by simply taking a look at the GFX scores each time I raised the FSB.....as even though it was the CPU I was overclocking, the GFX score continued to rise, and I wanted to see when the gains started to diminish.
All tests were run with Image Settings set to High Quality, and all Optimizations disabled.....using the 66.72 Forceware drivers.
Scores are listed in the forum of GFX | CPU | Overall:
6800GT @ 350/1000
200 FSB - 2.80GHz: 8,181 | 9,027 | 56,310
205 FSB - 2.87GHz: 8,259 | 9,238 | 57,092
210 FSB - 2.94GHz: 8,379 | 9,542 | 58,229
215 FSB - 3.01GHz: 8,445 | 9,768 | 58,971
220 FSB - 3.08GHz: 8,517 | 9,928 | 59,604
225 FSB - 3.15GHz: 8,565 | 10,144 | 60,229
230 FSB - 3.22GHz: 8,625 | 10,317 | 60,834
235 FSB - 3.29GHz: 8,661 | 10,641 | 61,564
240 FSB - 3.36GHz: 8,730 | 10,898 | 62,336
245 FSB - 3.43GHz: 8,757 | 11,068 | 62,759
250 FSB - 3.50GHz: 8,799 | 11,266 | 63,294
255 FSB - 3.57GHz: 8,817 | 11,523 | 63,791
260 FSB - 3.64GHz: 8,844 | 11,691 | 64,172
265 FSB - 3.71GHz: 8,874 | 11,949 | 64,721
270 FSB - 3.78GHz: 8,883 | 12,144 | 65,062
6800GT @ 425/1100
200 FSB - 2.80GHz: 8,886 | 9,058 | 59,625
205 FSB - 2.87GHz: 9,033 | 9,289 | 60,789
210 FSB - 2.94GHz: 9,201 | 9,584 | 62,161
215 FSB - 3.01GHz: 9,321 | 9,751 | 63,079
220 FSB - 3.08GHz: 9,393 | 9,957 | 63,840
225 FSB - 3.15GHz: 9,492 | 10,164 | 64,721
230 FSB - 3.22GHz: 9,588 | 10,412 | 65,664
235 FSB - 3.29GHz: 9,714 | 10,645 | 66,716
240 FSB - 3.36GHz: 9,765 | 10,838 | 67,336
245 FSB - 3.43GHz: 9,873 | 11,088 | 68,316
250 FSB - 3.50GHz: 9,966 | 11,259 | 69,065
255 FSB - 3.57GHz: 10,062 | 11,523 | 70,054
260 FSB - 3.64GHz: 10,110 | 11,635 | 70,483
265 FSB - 3.71GHz: 10,185 | 11,925 | 71,374
270 FSB - 3.78GHz: 10,203 | 12,148 | 71,876
As you can see, when the GT is/was clocked at is default 350/1000, the advances in the GFX score almost came to a stand-still when I hit 245fsb...only increasing 27 points beyond the score at 240fsb. The trend continues through 'till 270fsb, and by then it has started to become even less of a gain, a measly 9 point jump going from 265fsb to 270fsb. With the card clocked at 425/1100 however, the results were much different. For starters, the gains to the GFX score were much more prominent each time I raised the FSB, which is to be expected with the higher clock rates on the card. It was interesting however to see that even the transition from 265fsb to 270fsb still netted me a gain of 18.....signalling that the CPU was just then becoming less of a factor in the GFX score.....a whole 25fsb ( 300MHz) later then when the card was running at its stock clock rates.
I may re-run these tests once I get my 3.2E running on my water cooling that's starting to arrive this week.....as I'd like to see how the numbers look once I hit and/or cross the 4GHz mark. I think I may also be tempted load up Doom3 when I get the 3.2E and run these exact same tests in Doom, to see how performance scales in a real life game, and in an OpenGL environment.
6800GT @ 350/1000
6800GT @ 425/1100
