Aproximate 300$ Budget Build
Sathsayin
Building for a schoolteacher friend who is still in college. Must be ablte to run MSOFFICE and at least 5-10 Internet explorer windows,
Avast Antivirus and either play pandora or Stream movies like netflix. Onboard is o.k. for now.
She used an intel gma95c integrated before on a laptop with 8mb shared....
300 is what she is asking ... I would say 320 MAX.
3) Where do you live?
Not near any computer Places... Everythign will be bought from Newegg only.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
Case,PSU,Motherboard,Ram,harddrive,DVD burner, Proccesor.
Emachines keyboard,mouse speakers, 1280by1024 emachines crappy lcd.
6) Will you be overclocking?
no
asap
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Needs to be legacy to connect her printer and keyboard and mouse.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes provided by her college. win7 32 bit
Burner needs to be silent if changed (NOT LITEON). Good warrenty on the harddrive, at least 1mb l2 cache on cpu, and not a foxcon board.
This is what ive come up with .... I'm not familar with AMD lately so not sure what would equal peformance.
but hands down 320 is max no more whatsoever.
1 SAMSUNG 24x DVD Burner - Bulk SATA Model SH-S243N/BEBS LightScribe Support - OEM Item #: N82E16827151216 $24.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151216
1 Western Digital Caviar Blue WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive Item #: N82E16822136073 $54.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073&Tpk=N82E16822136073
1 G.SKILL 2GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model F2-6400CL5S-2GBPQ Item #: N82E16820231121 $44.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231121&Tpk=N82E16820231121
1 GIGABYTE GA-G41M-ES2L LGA 775 Intel G41 Micro ATX Intel Motherboard Item #: N82E16813128388 $56.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128388&Tpk=N82E16813128388
1 Intel Celeron E3300 Wolfdale 2.5GHz LGA 775 65W Dual-Core Processor BX80571E3300 Item #: N82E16819116264 $51.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116264&Tpk=N82E16819116264
1 Antec Three Hundred Black Steel ATX Mid Tower Computer Case
Item #: N82E16811129042
Antec EarthWatts Green EA-380D Green 380W Continuous power ATX12V v2.3 / EPS12V 80 PLUS BRONZE Certified Active PFC Power
Item #: N82E16817371033
-$25.00 Instant -$20.00 Combo $84.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.492902
Subtotal: $318.93
Calculate Shipping Shipping: $9.67
Discount From Promo Code EMCYWNT34
Promo Code: -$15.00
Grand Total: $313.60
THX alll
Honestly at this price range I would get her a prebuilt system like this emachines, unless you want to end being her tech support agent instead of Newegg/Acer.
Wait does her printer still uses the parallel port or something?
I assume he means he needs a mobo with a parallel port and some ps/2 ports. I don't even know if you can find a new board with those on it anymore.
I would definitely recommend going the pre-built route here. You may be able to find a Dell refurb or something in that price range.
Most of today's boards have PS/2 ports for the keyboard and mouse, and there are parallel-to-USB adapters available.
Since it's still Back to School season, and because you're working with such a limited budget, I also agree with the recommendation of going with a prebuilt system.
just out of curiosity but what do you have against lite-on and foxconn that their parts cant be included in your build?
Foxconn makes many OEM boards and supplies parts to several manufacturers. I'm running a Foxconn F35A motherboard that has my Q6600 completely stable at 3.4GHz. No qualms with their products here!
I pretty much ordered the parts below to build a $300 dollar computer for my uncle. Like other members have said, prebuilts might be worth considering at this price point, maybe check out the Dell outlet. I'd rather build one though.
Western Digital Caviar Blue WD5000AAKS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
$54.99
Crucial 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model CT2KIT12864AA800
$39.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148163
Antec Three Hundred + BP430 Black Steel ATX Mid Tower Computer Case 430W Power Supply
LG 22X DVD Burner - Bulk Black SATA Model GH22NS40 - OEM
Combo : $89.95
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.492952
BIOSTAR TA785 A2+ AM3/AM2+/AM2 AMD 785G ATX AMD Motherboard
AMD Athlon II X2 255 Regor 3.1GHz Socket AM3 65W Dual-Core Desktop Processor ADX255OCGQBOX
Combo : $102.98 -$10MIR
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.496222
Total : $297.91 and $10 MIR
$54.99
$39.99
Combo : $89.95
The BP430 is one of two PSUs in the Basiq series that are made by Delta rather than FSP.
