- Aug 18, 2006
If I get a Mac, which will be my first one, it may be the MacBook Air M1. I’m actually very impressed by this chip.
Sorry man, do not think it works like that on the new M1 ARM architecture.Any OS that runs low on RAM from high memory usage is going to hit SWAP and thrash the disk, be it a HDD or SSD.
That 'issue' isn't limited to Apple computers, and I see it as more an issue of lack of RAM and/or over-usage of programs or data being loaded.
Have you been able to see what your RAM usage is on average, and how many writes you've had on your SSD?
Unless aggressive swappiness is a thing on MacOS, I don't see how there is any 'bug' to fix, outside of each individual's RAM usage.
Here's a way to disable SWAP on MacOS: https://windsketch.cc/macbook-disable-swap/
There's your 'bug' fix.
Unless there is something special about that architecture, which I doubt (sounds more like an OS configuration/behavior than anything else), the issue is most likely users running out of RAM and thus hitting SWAP.Sorry man, do not think it works like that on the new M1 ARM architecture.
_____
From your article:
1. Disable swap
Be careful! Disable swap would cause kernel panic if there is not enough RAM for processes. Take it at your own risk.
_____
I do believe there is something they can do to fix hitting the drive so hard for swap space. I think that is in the works and should not deter people from getting one.
With the 16GB Ram I have my average usage is 10GB with a lot of things opened. I switched to Safari for browsing as it is optimized for the M1, beefed up security and privacy too. Use DuckGo for search and Dashlane right now for passwords and secure info.
It's like that for every OS and CPU ISA out there, and disabling SWAP doesn't hurt anything as long as the system doesn't run out of RAM.Be careful! Disable swap would cause kernel panic if there is not enough RAM for processes. Take it at your own risk.
All good points I agree wholeheartedly. I also think the SSD cell quality (if they used quality SSD's) would prolong the life of the drives considerably as well. Which getting a larger drive to disperse the writes could also extend the life. However, my biggest concern is without the added warranty is if they are stating (based upon the article I originally posted) that SSD failure could occur within 2yrs or less and Apple does nothing to support those people who were brave enough to purchase an M1 when first released, it could be a disaster for some customers like me. However, based upon the butterfly keyboard recall they did, I feel Apple would do the right thing and help those customers affected. So aside from this one issue, (which is a big one I agree), it really is a phenomenal machine and experience. Especially since you can open iOS apps now on MacOS with the M1. The ecosystem connectivity, ease of installing and removing software and ability to message and create come together extremely well. So I use my Razor 2019 for VR/Gaming and as a backup but love the quality and fluidity of the iOS/MacOS ecosystem for everything elseUnless there is something special about that architecture, which I doubt (sounds more like an OS configuration/behavior than anything else), the issue is most likely users running out of RAM and thus hitting SWAP.
I could be wrong about that, and MacOS managing inactive programs by aggressively putting them into SWAP, but doing so will definitely burn through the SSD much faster - Apple probably should have thought that one out a bit more if that is the case, or if they have, they have accepted the costs of replacing the motherboards if/when the time comes as a business decision.
Again, I don't really see how this is a 'bug', but I do see it as either poor management and planning, or an acceptable loss (knowing Apple, it would be this).
I don't think the SSD thing will be much of an issue outside cases where people are frequently exceeding more than their total ram, which shouldn't be consistent unless they vastly underprovisioned their system when planning their usage out. Which regardless of what kind of system you were using would cause a failure the only issue there is the inability to replace the components yourself which.... ouch.All good points I agree wholeheartedly. I also think the SSD cell quality (if they used quality SSD's) would prolong the life of the drives considerably as well. Which getting a larger drive to disperse the writes could also extend the life. However, my biggest concern is without the added warranty is if they are stating (based upon the article I originally posted) that SSD failure could occur within 2yrs or less and Apple does nothing to support those people who were brave enough to purchase an M1 when first released, it could be a disaster for some customers like me. However, based upon the butterfly keyboard recall they did, I feel Apple would do the right thing and help those customers affected. So aside from this one issue, (which is a big one I agree), it really is a phenomenal machine and experience. Especially since you can open iOS apps now on MacOS with the M1. The ecosystem connectivity, ease of installing and removing software and ability to message and create come together extremely well. So I use my Razor 2019 for VR/Gaming and as a backup but love the quality and fluidity of the iOS/MacOS ecosystem for everything else![]()
